Results 1 to 18 of 18
    Default Removing the adhesive tape strips off the back of door molding trim
    I recently acquired a set of full side trim molding pieces for my 1985 Mustang. I had to remove them off of a set of doors and fenders which were rusted out and found that the tape and it's adhesive are still incredibly stuck to the moldings. What tricks have people used to remove the old tape strips from the back of these moldings? I also would be interested in any tricks you have used when painting these moldings.
    Use a propane torch... carefully. Just a little heat and the metal will pull right off. You need a vice or a second pair of hands. I used a scraper or razor to get a little corner loose then grab it with some pliers and heat the metal and pull
    Yes. Pick enough that you can grab it with needle nose
    Power tools can be too aggressive but are faster.
    Have one of those electric oscillating multi tools?
    Uniquely handy for this kind of job and many others.
    Put a dull blade or scraper blade and go to it.
    Or a wire wheel on a drill? A Scotchbrite wheel?
    Doing this by hand is torture and takes a long time.
    They say keep the metal on to prevent shrinking of the molding.
    Just remove the foam.
    Jan 2006
    Western MA
    Paint stripper wheel will quickly remove any remaining goo after you scrape as much as you can with a stiff putty knife or even a wood chisel (careful).
    And the stripper wheel will leave the metal strips clean and ready for new double-sided tape.
    https://www.walmart.com/ip/3M-TM-Hea...43&athena=true
    JT
    1986 SVO Mustang - 1C
    I used a long handle razor blade holder and it worked great. My issue now is I can't get the moldings to flatten out, they are so curled, especially on the ends. I probably will buy reproduction pieces.
    Brant
    I do intend to leave the metal to avoid the curl
    Lay them out flat in the sun. Mine were curled up bad. I took off the metal and layer them out in the sun a couple days. Now they are perfectly flat
    Jan 2006
    Western MA
    Don't take the metal off the 85 / 86 moldings as they shrink.
    It's usually OK to remove the metal from the 79-84 moldings, but only if they are badly deformed.
    I still got the metal on there, just haven't gotten them to flatten out. Maybe in the sun with boards on them, I'll give it a try before I buy repros.
    Brant
    Hang 'em with weights? There are past posts of doing that.
    3M tape does take curl out. No way to fix on car. Have to remove and retape.
    I used clamps or propped wood stud sections on the molding ends overnight when possible.
    Removed everything way back. Did not know of the metal thing. 79 will shorten up too.
    Also, mark where the short ones go if doing all of them at once.
    All look the same, are not.
    Also remember if you remove all the moldings at the same time, the moldings that match up to the bumpers are thicker than the moldings between the wheels.
Size:  79.1 KBName:  IMG_20180624_151124177[1].jpg
Size:  123.6 KB Unexpected discovery. When I was working on my side moldings I discovered the GT piece that had flaked away was an aftermarket decal and underneath was the original still in great shape, just cleaned them up with acetone and now are ready for paint. Here are some more pics of the rest of the moldings after I cleaned them. I included one piece of the hard molding that I had already painted to show the difference.Name:  IMG_20180624_151129318[1].jpg
Size:  116.1 KB Some are still a bit curled, especially on ends, something else to work on.Name:  IMG_20180624_170254550[1].jpg
Size:  78.3 KBName:  IMG_20180624_170259375[1].jpg
    I used a 4 inch wide heavy duty putty knife with a large hammer to take the trim off the rusty donor doors and fenders. This took them off straight and true without distortion. I then took a heavy duty cup wire wheel on a variable speed polisher. It took the tape off in glue gobs but left the clean metal. This worked well and allowed me to put new 3M trim double sided tape on for a clean install. I have to paint the front bumper and headlight area before I paste 'after' pictures but want to thank all those who provided suggestions.
    Can't wait to see the pics. I got my headlight buckets painted as well as the bumper charcoal trim, just waiting to get the rest of them white. Hopefully will be spraying white this weekend.
    Brant
    May 2003
    Roseburg Oregon
    I use a rubber wheel for removing decals and double sided tape.
    Works like magic , and does no harm .
    Get them at any autobody supply store .
