Results 1 to 4 of 4
    Default Need help with nuetral safety switch
    85 GT with T5...I have 2 neutral safety switches, one is a normally closed switch and the other is normally open. Which one is the correct switch for me to use? Engine is currently out but about to go back in, once its in I won't have room to install the switch. Help will be greatly appreciated!
    '85 T-Top GT 5.0L HO 5spd
    Breathing upgrades/Stock block
    May 2016
    Lake City Pa 16423
    By saying neutral safety switch, do you mean clutch switch? A neutral safety switch would be on an automatic trans. The clutch switch
    's are on the pedal assembly. You will need the normally open switch for the ignition circuit. Then the harness at the trans will use a jumper wire.
    The clutch switch is located on the clutch pedal, this is located on the top of the transmission. When you unscrew it from the case you can see it has a ball and when the ball is pressed it activates the switch. It may be called something other than neutral safety
    Dec 2013
    Connecticut
    You may be looking at a switch for your backup lights.
    It should close when you shift into reverse.
    Neutral safety switches are for automatic transmissions.
    Ray
    65 Galaxie 500 XL 390 auto
    2A
