Results 1 to 13 of 13
    Feb 2006
    Allentown, PA
    Default SVO Outer light removal
    I'm guessing accessing the outer light is through the wheel well with the inner liner removed? What is the chance the nuts will come off of a 34 yr old light without breaking plastic? I've been putting off the job to avoid hearing the crunching of old plastic.
    If you are talking about the SVO outer light, I believe there are some nuts you can reach going up behind the bumpe4 cover and in front of the fender liner. It’s been awhile since I have been in the svo..
    Feb 2006
    Allentown, PA
    Yea, SVO.
    Would like to get nice and close to it so I can soak it in some penetrating oil.
    Depending on what all you need to do, sometimes I have found it easier to remove the entire front bumper cover assembly from the car. That allows you to flip it over on a stand and get to all the hardware holding the lights in place. Yes, more work, but may save you from breaking the lights on the SVO and you know how difficult used ones and even good used ones are to find. Good Luck!
    Looks like just 2 studs. Here is a picture from eBay.
    Yes there are only 2 studs for the outer lens, the issue is usually one of two things. Either the studs back out of the plastic housing and you have to use a pair of vice grips to remove it from the actual header support. The other is the nut is corroded on the stud and you end up snapping the stud off in the housing or breaking the housing while trying to remove. That was the reason why I suggest sometimes removing the whole front cover and lights and then flipping it over to work on it. It allows you to get a better view of what's going on and also allows you to get directly at the hardware.
    FEP Member endub's Avatar
    Aug 2011
    Fayetteville AR
    You can get to them without removing the bumper cover. Just be careful.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Feb 2006
    Allentown, PA
    You are making me feel much better.
    Maybe I'm wrong but the outer lights on an SVO don't look to be part of the bumper cover so even with the cover off I don't think the nuts are any more accessible??
    For now my milk bottle 'lens' is doing the job.
    Quote Originally Posted by endub View Post
    For now I'm avoiding but when I tackle it, I'll be careful, very careful!
    Aug 2003
    Villa Park, IL
    Yep, you just have the two. Spray the crap out of them with penetrating oil. You might need to heat them a bit too. Be careful because they bolt right up to the headlight panel. Just go slow, 1/4 of a turn then back and ease them out. The lamp will need to be moved around a bit to clear the bumper cover.
    Quote Originally Posted by rodster View Post
    Sorry I wasn't trying to be doom and gloom, just making you aware of the issues with these lights. My recommendation was to remove the entire cover and header panel as a unit since removal of the bumper cover from the header panel requires drilling out rivets, they are essentially once part at this point in time on the car. If you removed the front bumper cover assembly Then you would have full access to the backside of the lamps and have a better chance of preventing breakage or damage. Yes it is a bit more work, but if you are truly concerned with damaging the lamps then I do recommend it.
    You can apply plenty of penetrating oil to the studs before hand and then attempt to remove them while still on the car. If they act like they are going to break or strip out, then you may reconsider the bumper cover removal. I also recommend a 50/50 mixture Acetone/Transmission Fluid as a penetrating oil. Generally cheaper than most off the shelf brands and works really well. Good Luck!
    Feb 2006
    Allentown, PA
    Quote Originally Posted by MIKE'SVO86 View Post
    Thanks Mike. Plan A.
    Fully understand, I've been around this stuff for awhile and appreciate your advice and warnings. Just found it 'funny' how I could see both of those possible outcomes all to clear.
    Oh, front bumper cover assembly, gotcha. Definitely will look into it. Didn't realize the assembly could be removed as one piece.
    Got some of the 50/50 mixture on my workbench.
    Thanks again....
    Jul 2016
    Duncannon PA
    Trey has a good point Rod. It might be more time consuming but safer in the end.
    Feb 2006
    Allentown, PA
    Quote Originally Posted by dagenham View Post
    Yep, very valid point and I will certainly consider it. I have to see what is involved but for now I'm having more fun driving it.
