Results 1 to 5 of 5
    Banned
    Feb 2017
    Birmingham AL
    Default power windows - front back tilt?
    Good afternoon,
    I ran through the guide I found in another post that covers adjusting the T-top widow glass. I have an issue where the drivers glass will start out level and then it tilts backward and gets stuck on the rear pillar seal.
    after closer inspection, it really seems like the window will tilt fore and aft, quite freely. I have checked and all the nuts are tightened down. What might I be doing wrong with this adjustment? or do I need to replace the power window regulator door guts thing?
    Thank you
    FEP Super Member
    May 2003
    Roseburg Oregon
    The plastic guides have worn .
    They are fairly cheap , but not that easy to replace .
    Not impossible , just tight space .
    Banned
    Feb 2017
    Birmingham AL
    Can you get those at the auto part store?
    FEP Super Member
    May 2003
    Roseburg Oregon
    No you cant , get them from LMR I believe .
    Banned
    Feb 2017
    Birmingham AL
    I'll order some in and see if that fixes. Thanks.
