Page 2 of 2 FirstFirst 12
Results 26 to 47 of 47
  1. #26
    Grand Rapids, MI
    Wait a minute... The thing i kept hearing about stud mounted rockers was that they are stronger because they don't use press-in studs. But no Ford head I've seen apart uses press-in studs anyway! It's bolts going in to threaded holes! It's just the studs being stronger than bolts bandwagon that ARP wants us all to jump on! Well, that makes me feel better about using pedestal mount. Maybe I'll get some upgraded bolts to go with them... I see the Crane ones seem to be back in stock on Summit.
    That's not to say studs AREN'T stronger than bolts... I know they are, but still, probably beyond my needs. Not worth the money and trouble to me.
    Old SBF before the advent of the pedestal mount rocker used pressed in studs. The D0 heads on my '91 Crown Vic have pressed in factory studs.
    I personally wouldn't feel bad at all about using factory style pedestal mount rockers for your application. Obviously now would be the time to have the heads machined for screw in studs, and it would be awesome to have full roller rockers, but I don't know if that is the best use of your money on this engine.
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
  2. #27
    Every single combination is different so I can't sell you on them. I remember the magazine tests back in the day though. They put them on an otherwise totally stock HO 5.0 engine and got 6 HP. That was it. I think it was 2 or 3 ft lb of torque but I know the HP was 6. Nothing anyone could feel. The same car on two different days might have a 6 HP difference on the same dyno. That being said, I have had a set of brand new Crane pedestal mount "Cobra" 1.7 rockers still wrapped in the box for probably 20+ years. I guess I was waiting on the right build to install them on, LOL. I just can't see taking off the upper intake for 6HP. I realize your engine will not be stock which is why I said every combo is different. Seemed like a good idea when I bought them and then I saw the dyno tests.
  3. #28
    Interesting, I didn't know that (obviously )!
    Does anyone have a ballpark idea of what it costs to have your heads machined for stud mount? Mostly just curious at this point.
    I see the Scorpion rockers are less than the Crane ones.
    I'm also curious what purpose the valve cover baffle serves. If it's beneficial, I'd rather not get rid of it. I see LMR has a set of SEFI ready valve covers that cost LESS than the valve cover spacers they offer that are higher to fit roller rockers. They are unfortunately chrome, so I think for my engine I would want to probably paint them to match my intake or at least put satin clear on them. I found some '94-95 Cobra valve covers and they wanted more than the spacers, even. Nice try, guy.
  4. #29
    Yeah. Well yours are a different ratio though, so shouldn't that make a difference itself?
    I think I'm getting that they are selling you the durability and consistency of them rather than the power gain....
  5. #30
    Yes, the 1.7 would simulate or imitate a larger cam. A cam that has more lift than it actually is. So technically, a 1.6 ratio should not even gain 6 HP all other things being equal. Back when I bought these, the fact that Ford was using them OEM made them much cheaper than a 1.6 ratio rocker in another other form. Of course as I said, that was decades ago. So none of that applies now. Newer heads and CNC machining, CAD designed and developed cams etc. I was just relating my experience.
    Unless you are prepared to do a before and after dyno run the same day with only changing the rockers on the same car, we will never know. Butt Dynos have about a 40% error factor, LOL. The Dyno....She don't lie. Everything else we all say and anything else is pure conjecture. Because it ain't your car and your engine.
  6. #31
    The dyno tests back in the day showed decent results with stock HO cam and E7 heads. Especially once a 1.7 is added on the exhaust side. No increase with intake only. Most of the increase seen when the 1.7 on exhaust was added.
    the higher ratio effectively increases both lift and duration. the valve spends more degrees at or above 0.050 lift. You get a split duration favoring exhaust with a 1.7:1 only on exhaust.
    Add great heads to the equation and a 385HP 302 with 1.6’s became a 403HP 302 with 1.7’s.
  7. #32
    Apr 2008
    Waikoloa , Hawaii
    If that 302 was making even 385 crank horsepower, I'd guarantee it had more than a stock cam, plus good heads and intake
    1986 CHP SSP Coupe
  8. #33
    Interesting stuff. How much more of a concern is piston to valve clearance with them out of curiosity?
    I will be doing 1.6 ratio on mine if I go to rollers. That's what my cam is designed for. It showed up yesterday, by the way!
  9. #34
    Jul 2009
    Chicago, south subs
    what does fti recommend ? Higher lift might require rollers. Or at least stamped with a longer slot.
  10. #35
    Jan 2005
    Cordova, TN
    Check out Engine Masters video series. They tested this! Stamped steel rockers versus roller rockers. HP difference not even in the error tolerance of the dyno. What was a standout was 3/8 vs. 7/16 studs. 3/8 flex so bad it was very noticeable that the HP dropped a measurable amount at higher RPMS. The main reason for converting to studs on a stock head is that higher spring pressures will pull the pressed in stud out of the head. No bueno.
  11. #36
    Check out Engine Masters video series. They tested this! Stamped steel rockers versus roller rockers. HP difference not even in the error tolerance of the dyno....
    This. There is no perceptable gain. It's a popular mod and I am not sure why exactly. The new $26,000 (nope, not a typo) Chevy LS9 crate motor does not even have FULL roller rockers, only roller trunions and it has 638 HP.
  12. #37
    He said the springs do not require going to stud mount rockers. But I should make sure the mounting bolts are of premium quality.
  13. #38
    Jul 2009
    Chicago, south subs
    When you get into higher lift, the length of the slot in your stock rockers might not be enough to accommodate the extra lift, causing bind or other mayhem. I'm not sure how high you can go with stock rockers which is why I asked about Ed's recommendation. If they will work for your application, that's great.
  14. #39
  15. #40
    Quote Originally Posted by ThunderStruck View Post
    The Ticking
    The originals tick more than rollers? I've never made a comparison myself.
  16. #41
    Been running the Proform 1.6 roller rockers for about 1.5K now. No issues. Spun to 6-6.2K RPM a few times. Installed on a mild GT40 / F cam build. Bought the shim kit, new rocker channels, stock length pushrods, TFS spring kit and Comp Cams spring locators at the same time when I had the heads redone in 2016. Just couldn't see myself reinstalling the original stamped rockers back on my nice shiny newly rebuilt heads :-).
    05 Corvette Z51
  17. #42
    Quote Originally Posted by 84lxvert View Post
    Yeah, that's kind of where I'm at with it, to be honest. I'm glad yours are working out for you.
  18. #43
    I ended up getting the Scorpion ones. They came yesterday and they are ohhhh sooo prettyyyyyyyyyyyyy...... They make me happy.
  19. #44
    Nice choice!
    Matt
  20. #45
    Thanks! I enjoy looking at them most of all.
  21. #46
    Brad,
    I installed a set of Scorpion roller rockers in my 347 when I built it 5 years ago and they've worked well for me. Granted, I've only put about 2000 miles on the motor so far. Couple things that sold me on them is that they're made in USA and claim a lifetime warranty. I'd venture to guess they will work well for you.
    Thomas
  22. #47
    Brad,
    Good to hear! They sure do seem solid!
