Results 1 to 4 of 4
    Default Hot rod garage does a four eye
    I am shocked nobody here is discussing what they did...
    FEP Member brianj's Avatar
    Feb 2012
    Raymond, New Hampshire
    Blog Entries
    2
    Haven't seen it. I pretty rarely watch tv.
    It's not on TV, an internet thing. Was on Youtube, not sure if it still is.
    If they didn't try to rush everything, they probably would have had better results. I like that they didn't try to cover up how much of a failure the whole thing turned out though. It was like they opened up a mustang mag from 1999 and did those mods. Trick Flow heads, B303 cam, roller rockers, Edelbrock intake, bigger carb.
    Jess
    Previously owned;
    When they tossed the ignition I knew it was going to go downhill. Hopefully they will return to it and try to figure out what they did wrong. Maybe pull the engine and put it on engine master's.
