Results 1 to 5 of 5
    Default Quick wire cleaning tip
    I was doing some wiring stuff on my truck and couldn't see the wire colors because of the filth covering them. Turns out baby wipes work pretty good at cleaning wires. Carb cleaner was evaporating before I could get the wires clean. The wipes are much nicer to work with too.
    Jess
    Previously owned;
    FEP Super Member
    May 2003
    Roseburg Oregon
    Super clean by Castrol is your best friend .
    FEP User
    Jul 2010
    Winnipeg Manitoba Canada
    WD40 is excellent for cleaning wiring.
    And all kinds of other parts too but especially on rubbers and plastics.
    And who doesn't have a can sitting around?
    FEP Super Member
    May 2003
    Roseburg Oregon
    Ever tried to wrap you wires after using wd40 ?
    Jan 2011
    Vancouver BC Canada
    Hand cleaner without pumice works well for cleaning wiring too.
