Thread: Roller Lifters
    Default Roller Lifters
    I have always changed lifters with new cams.
    Does it stand true for roller lifters?
    Next:
    I am using a set of new ford performance m-6500-r302
    Is the extra cost to upgrade to M-6500-302E for 300-400 more rpm's worth the $90.00 upgrade?
    I will run max rpm's of 6500 at times...
    Ed
    Apr 2008
    Waikoloa , Hawaii
    If they're in good condition, you can reuse them, they don't form a wear pattern like a flat tappet does. I've reused MANY sets.
    As for the difference in the two, I don't see the "E" listed anywhere, what is the claimed difference / upgrade? Those r302 should be good for 6500.
    1986 CHP SSP Coupe
    Jul 2010
    Houston (Clear Lake), Texas
    Roller lifters are fine with a different cam. I am utilizing the stock roller lifters in my 85 GT on an E-303 cam I turn well above 6,000 rpm.
    HAD
    HAVE
    Just wanted to know before I give the used ones away...
    thanks,
    Ed
    Hey I'm old, the part number is M6500-R302H for the lifters.
