Results 1 to 25 of 34
    Default What have you fabricated
    What have you fabricated on your car that your most proud of?
    Jan 2007
    Quartz Hill, California
    Through floor sub frame connectors, came out pretty decent!
    Robert
    My RS in Action
    I've made a fair number of sheet metal mounting brackets for various things. Cooling fan, ECM, parking brake cables, electronic components, etc. I guess I'm proud of them because I have ZERO metal working tools, and do not weld. It's just me and a vice, the side of my workbench, and I've made EXTENSIVE use of my air powered cut-off tool. Oh, and BFH.
    Oct 2014
    Calgary, Alberta, Canada
    I fabricated a ton of stuff on my car, but the aluminum interior is the most showy part.
    Name:  2018-02-09 17.04.58_resize.jpg
    Jul 2004
    Montebello, CA
    Not my capri but this is my 69 falcon gt coupe that i built to look like the aussie falcon which ford never built as a coupe
    Past 4 eyes-
    U.S. NAVY 1980-2009
    Feb 2009
    Snohomish, Wa
    I made the oil pan on the 400 in my Black Magic. I also shortened the driveshaft on it.
    Dave
    1983 Capri RS Turbo
    1981 Black Magic 400 c6
    93 F-250 351 5sp 4x4
    Building the manifold, making a pulley system, and modifying a Shelby mustang's blower to fit a 351w block. All nice and low, almost fits under a stock hood.
    Jess
    Previously owned;
    Apr 2010
    Portland, Oregon
    Jess
    WOW!
    Feb 2012
    Mississauga Ontario, Canada
    That supercharger looks like it came from the factory. That is one thing amazing job.
    FEP Senior Member FuturaGuy's Avatar
    Jan 2005
    Windsor, CT
    I fabricated a wire harness that ties the '98 Mod Motor under hood wiring to an '88 dash and what little of the original wiring remaining in the '79 car. It's about 7 feet long, reaching from one kick panel, across the dash, and down to the other kick panel. I also added provision for power windows, power mirrors, and power door locks. The best - or most amazing - part was when I plugged it in, everything worked!
    I fabricated stories of races won.....
    Tony
    May 2013
    Berea Ohio
    The bypass-return contraption I created for about 10 bucks with a trip down the plumbing aisle, in order to reduce the ~9psi from the swapped-in "low pressure" in-tank electric fuel pump (previously a 1986 high pressure pump/system) down to a carburetor-friendly 5-6psi.
    The pressure being no-nonsense reduced and consistent by the small restriction threaded within (therefore adjustable) the bottom return fuel barb that's connected with the car's original fuel return line to the tank. Cool steady pressure fuel all the times makes Mustang a happy camper.
    Jul 2016
    Duncannon PA
    I'm working on putting an aftermarket radio in the glovebox of my wife's 67 cougar. Sounds easy enough. Not so much though.
    May 2002
    Wareham, Massachusetts
    I didn't really fabricate these but I modified them to be used for what I needed. The factory 3" dash speakers now contain my Kenwood 1" tweeters inside them. This means that I didn't have to fabricate my own brackets to mount them. From this:
    Pete Slaney
    1979 Mustang Cobra
    347/T-5/4.30's
    420 rwhp/380 rwt (New Motor)
    11.49 @ 121.86
    306/T-5/4.30's (Old Motor)
    307 rwhp/278 rwt
    12.38 @ 111.38
    May 2002
    To this:
    Pete Slaney
    1979 Mustang Cobra
    347/T-5/4.30's
    11.49 @ 121.86
    307 rwhp/278 rwt
    12.38 @ 111.38
    May 2002
    I also fabricated this throttle bracket for my 306 dual quad motor out of plywood by cutting, molding, and shaping it to the way I wanted it. I mounted it and tried it out, then took it to the machine shop next door to where I work and they recreated it out of aluminum. The aluminum piece that actually holds the throttle cable that moves in the slide hole is actually on my 347 stroker motor at the moment (I switch it from motor to motor, depending on which one is in the car at that time).
    Pete Slaney
    1979 Mustang Cobra
    347/T-5/4.30's
    11.49 @ 121.86
    307 rwhp/278 rwt
    12.38 @ 111.38
    You all have a lot of talent. Be proud
    Quote Originally Posted by flinfantryrebel View Post
    Funny, love your imagination!
    Quote Originally Posted by Hissing Cobra View Post
    very cool!
    very good. Love the reuse of things.
    awesome!!
    Quote Originally Posted by FuturaGuy View Post
    wiring is one I always cringe on. Not that it stops me, just makes me do a little more thinking
    Jess
    Nice!! Love it
    I like! Different is always cool in my book
