Results 1 to 6 of 6
    Jun 2003
    Santa Maria Ca
    Default 28 or 50oz balance mystery
    I picked Up this flywheel a few years ago as part of a top loader setup. I plan on using a toploader in a 50oz build soon, and canít tell what the balance of this flywheel is. Itís a 157 tooth, and has 6 holes for a long style clutch. There are no markings anywhere to tell if itís 50oz or 28oz. Can it be determined from the balancing holes in the backside what this is? Iím hoping itís a 50oz, as thatís what I need for my build.
    85 Saleen Mustang(s)
    May 2003
    Roseburg Oregon
    Since all top loaders were connected to a 28 oz flywheel , that is what i would assume this is
    Apr 2008
    Waikoloa , Hawaii
    EXACTLY what I was going to say...
    1986 CHP SSP Coupe
    Jun 2003
    Santa Maria Ca
    It’s an aftermarket piece, so I’m not going to assume.
    The guy had parts and motors from several generation of cars, including HO 50oz stuff.
    Apr 2008
    Waikoloa , Hawaii
    So there was a slim possibility he had the topload and flywheel in a 5.0 HO? That's the ONLY way this would be 50oz.. I'm no gambler, but I'd bet it's 28oz. Without any part numbers, it's gonna be hard to say honestly. No way I'm aware of to 'check'. And judging from the resurfacing it needs, I'd look into a new SFI piece myself regardless. Good luck
    1986 CHP SSP Coupe
    Jun 2003
    Santa Maria Ca
    There’s a high possibility he had a 50HO with the toploader in his supercharged 65 fastback. The surface you’re seeing is the backside, where the balancing holes are drilled. From the front, it shows normal wear from the clutch. It looks like a really nice part from the front.
