Results 1 to 6 of 6
    Mar 2015
    Rose Hill,Kansas
    Default Hood differences
    Is there any difference between Mustang 79-86 and Capri hoods 79-86 besides the scoops and vents.
    Yes. Capri is like 1979-82 Mustang but not 1983-86.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Mar 2015
    Rose Hill,Kansas
    Thanks, due to new engine I need to buy new aftermarket hood or cut up my Capri hood for scoop. On the fence on what I need to due. Leaning towards buy new hood and saving my Capri hood.
    Spacers at the K member is what the mod motor swap guys do. Adds caster too which improves steering.
    Quote Originally Posted by dtmilsap View Post
    What engine are you installing?
    Drop engine mounts can be used for the 302/351W if you need added clearance, obviously solid 3/4" drop mounts can help in clearance, but you may not enough the lack of vibration isolation.
    As stated already you can use K member spacers to help gain some additional clearance too. I am not a huge fan of the option, but sometimes it is a viable option rather than cutting up a good hood, etc.
    If none of that will work, then HO Fibertrends does offer a 2.5" Cowl hood so that's an option. http://www.hofibertrends.com/1979-19...ctionhood.aspx
    Name:  Capri Cowl2.JPG
    Mar 2015
    Rose Hill,Kansas
    If none of that will work, then HO Fibertrends does offer a 2.5" Cowl hood so that's an option. http://www.hofibertrends.com/1...621...ctionhood.aspx
    Engine is 302/363 dart shp, Edelbrock air gap, 750 carb with 1" spacer. I bought the 2.5 cowl hood from lmr and it arrived yesterday. Like a dummy I didn't ck sway bar clearance. Sway bar is touching oil pan. Going to drop sway bar to see if that gives me the clearance I need. One step forward, 2 back lol.
