Results 1 to 4 of 4
    Default Which flywheel is needed when swapping engines?
    If you take the 5.0ho in a 1984 gt350 out and put in a rebuilt engine with an 86 block, do you need to use a 28oz or 50oz flywheel? TIA
    Jul 2010
    Houston (Clear Lake), Texas
    Fitty.
    HAD
    HAVE
    If the stock crank was resused in the rebuild, then it should still be 50oz. If the crankshaft was replaced, then they could have used 28 or 50, so you'd have to find out. Where did the rebuilt engine come from? When I have engines rebuilt, they're always paired and balanced with a flywheel and harmonic balancer. My machine shop balances the whole setup together.
    Depends...when the engine was "rebuilt" what imbalance was used?
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
