Results 1 to 4 of 4
    FEP Member vdubn's Avatar
    May 2017
    Beaverton, Oregon
    Default SN95 Sway Bar Brackets for Fox Body, 1985 GT Sway Bar Brackets, Freshly Powdercoated
    I have two sets of these for sale.
    First is a set from an SN95, that used on the Fox Body lower the sway bar by about 1.5". Good for clearance for a Coyote oil pan, or for Mod motor, install, etc.
    $50 shipped for the set
    Second is a pair of freshly powder coated 1985 GT Sway bar mounts, in excellent condition. Will fit all 1993 and earlier Fox Body's.
    $35 shipped for the pair.
    Mar 2003
    Lowell, Oregon
    Does using the sn95 brackets require a different length rod at the control arm end?
    It's been a while since I studied these details.
    May 2017
    Beaverton, Oregon
    Nope, I am using a set just like these, and am using the same ends that I had with the stock mounts.
    May 2017
    Beaverton, Oregon
    Still available
