Results 1 to 15 of 15
    Default Several GT, SVO Wiring Harnesses, PW/PL Harnesses, Engine Harnesses and Connectors
    Just went through the entire tote of harnesses that I have had for over 15 years. I'm realizing I will not be needing them in the future.
    So, from left to right at the top.......both top and bottom are in the pics.
    Fuel Tank harnesses $20 each
    A bunch of PW/PL harnesses with switches. Mostly black but a few chrome. Some are cut. Also have several Power wires that run across the fire wall for the PW/PLs. Open to offers on these.
    Tail Light harness. $45
    1985.5/1986 Mustang SVO Light and Charging harness. $75
    1985.5/1986 Mustang SVO Engine harness. $175
    A bunch of misc harnesses and connectors that have been cut. There is a lot of them there. Open to offers.
    From left to right at the bottom.......top is included too.
    T-5 harnesses. $40 each
    Hatch harnesses including 3rd brake light harnesses and rear window defrost wiring. Open to offers.
    Body and Tail light harness. $50
    Body and Tail Light harness. $50
    1985/1986? 302 TFI Harness. Part of it has been cut but the section is there. $40
    Lighted mirror harness. $30
    (2) 2.3 Turbo Injector harnesses. $25 each
    (3) Solenoids-TAB/TAD $20 each
    (2) Dash Fuel Warning Switch and Relay. $10 each.
    Willing to combine harnesses and make deals on the package. PM me if interested in any. Thanks, Mike
Size:  50.1 KBName:  MVC-126S.JPG
Size:  40.7 KBName:  MVC-127S.JPG
Size:  49.0 KBName:  MVC-128S.JPG
Size:  44.3 KBName:  MVC-129S.JPG
    Bleed Ford Blue! '84 Grabber Orange SVO, '88 Saleen 1 of 4 w/Automatic, '89 Steeda, '71 DeTomaso Pantera GT5 Wide Body EFI 4.6 DOHC and some Old Ford Muscle w/ BB power. 1.21 Jigawatts!!?? PETRO EXPRESS=CITGO=BOYCOTT!
    Here are some more pics. They got loaded in a mix so there is no orders. You can see the different harnesses, so contact me if interested.
Size:  41.4 KBName:  MVC-130S.JPG
Size:  45.2 KBName:  MVC-132S.JPG
Size:  50.7 KBName:  MVC-133S.JPG
    Body and tail light harness shipped to 77301.
    FEP Senior Member 86gtstang's Avatar
    Jan 2009
    Chester,SC
    Mike do you have a black window switch for a convertible, drivers door
    Robert
    86 GT vert
    85 GT
    Sorry Robert, Nothing with the 4 switches for a convert.
    body and tail light harness, will that work in my 85 coupe?
    One is from a 85 Hatch so I would think they are the same but not totally sure. I still haven't had a chance to check to see if it will all fit in a flat rate box.
    I'll make that work, how about an engine bay harness?
    I have a engine harness that was cut. It was removed from the 85 Hatch as well. Not sure how it would work. The main part was cut. It's a TFI harness.
    How much for that?
    40 singles.
    got my parts today, thanks again. what do you have left?
    Great. Thank you. Basically everything other than what I sent you.
    I am looking for the plastic bezel that the passenger power window switch harness connects into in order to allow the switch itself to electrically engage in. The piece I need contains the threaded hole for the switch cover as well as a series of holes for the switch pins to engage in. I actually have the wiring I need I just simply need the plastic bezel that the switch slides into. In addition I could use 1 plastic bezel that covers the passenger power window switch and one which covers the power door locks once the switches are in place.
    I'm sure I have that. I'll take a look and send you PM to confirm.
