I am looking to put some modern lights in my 1985 lx convertible. I am going to add the relays as I know this is a big improvement. I was also looking at getting the HELLA 003177801 164x103mm H4 High/Low.
My question is about the high-beam light... I know I can get a Hella H1 lens. My question is why not get two sets of the h4. When I wire them up, I will no connect one of the wires. Then I can use the same bulbs for all four lights, If I ever have an issue, I can take the h4 bulb out of the HighBeam and replace the h4 in a low-beam.
Another questions: When low beams are on, just the Low lights on the outside would be on. When HighBeam, then both the HighBeam on the outside and the HighBeam on the inside would be on. Is that how it should be wired?
