Results 1 to 2 of 2
    Default 2001 Mustang GT Brakes Into 86 5.0 T-Bird?
    Recently picked up a beater Mustang (01 GT) with a 4.6 and 8.8 rear end. I was planning on swapping the rear end and front brakes and spindles onto the T-bird. Are these components interchangeable? If so what problems may I run into with suspension geometry? I have heard it is required to run a bump steer kit with this swap. Any and all info would be appreciated. I want to get this car stopping before I drop my motor in.
    Grand Rapids, MI
    Plenty of good information here: http://www.maximummotorsports.com/te...p_spindle.aspx as well as in the suspension and brake part of the forum on this board.
    The 2001 rear end housing will be physically wider than the T-Bird rearend. I don't know if that will be a problem for the T-Bird though since they ran longer axles than the (fox) Mustangs stock anyway. I'm not sure what the difference in track width is between the 2001 Mustang and your car.
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
