Results 1 to 4 of 4
    Default Door Moulding clips
    86 GT Convertible. Painted car and removed the moulding under the window trim. The moulding is about an inch wide and 48 inches long. It is held on with 8 clips that LMR says are no longer available. Does anyone know of a substitute clip?
    Dec 2011
    stanton,alabama
    I might
    Jul 2010
    Houston (Clear Lake), Texas
    I had the same issue with those plastic barrel clips on mine when I went through it 6-7 years ago. I went and bought some small firewall type grommets that fit into the holes in the top of the door then inserted the T fittings into them once slid into position. It has not been an issue since and I really like it because now that area is water tight whereas it was not before.
    HAD
    HAVE
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    For your reading pleasure, here is a thread on the reproductions, reproducing these plus the original part numbers are in there.
    http://vb.foureyedpride.com/showthre...arrel+nut+trim
