Results 1 to 2 of 2
    New User
    Nov 2017
    Round Rock, Texas
    Default Escort to 85-86 SSP Cap Modification
    Hello everyone,
    For those who might have a 85-86 SSP and need the front wheel caps, here is how I modified Escort caps. I bought some damaged Escort caps to practice on first. Here is what I was able to come up with....
    First, I am lucky to have access to a lathe. I put the Escort cap on the lathe and cut the center chrome cap at the parting line. Then I used a 2 1/2" wide X 1 1/2" tall PVC coupling and allowed 3/4" for the additional space in the "snout" of the cap.
Size:  51.8 KBName:  IMG_2684.jpg
    Then I cut the base of the coupling down to about .001.
    This allowed me to slide the coupling into the cap, so I know it is centered on the cap. Some epoxy between the snout and the coupling and on the chrome cap. A little filler in the gap on the snout and argent paint and in about an hour time, a usable SSP cap.
Size:  102.9 KBName:  IMG_2690.jpg
    Almost the same thing can be done using a dremel tool and a hack saw.
    Using a dremel, make sure you have the cap secure. GO SLOW when using the dremel, the heat will cause the plastic to bead-up if you go too fast. A little sanding on a good flat surface will help even out any uneven cuts.
    Then, secure the PVC coupling in a vice and using a hack saw, you can cut the coupling (3/4"). You can then epoxy the newly cut 3/4" spacer onto the snout. Same process, a little body filler and paint and you're all set.
    Just thought I'd share this with those 85-86 SSP owners who were in the same boat as me, searching for the unicorn 85-86 SSP caps!
    Just go slow and it'll turn out great!
    John
    Mar 2013
    DENVER CO, the 303
    Show some pics of the completed pics as well please. There was a thread on ssp.net that had the modification done. I have yet to attempt this but will soon enough.
