Results 1 to 4 of 4
    Default Help id'ing these pistons
    Friend of mine just got a motor with 30,000 miles on it out of a 1987 Continental. The weird thing about the motor is it's an E7 block but has E6 heads on it. He's pretty sure it's never been taken apart. He removed the heads and these are the pistons in it. Just a round dish in the center. Name:  received_1864944226861759.jpg
    Are these e6 pistons or something else? He's planning to use original GT40 heads( iron )and a TFS cam. He assembled the heads to the motor and using an 1/8 inch of play dough, he barely had any contact. Hopefully that will be enough clearance
    Jul 2010
    Houston (Clear Lake), Texas
    Those are not E6 pistons. They do look like E87 slugs as they have a dish like that, but they did also get four valve reliefs. Is the cam a roller or flat tappet unit?
    HAD
    HAVE
    They look like the same no valve reliefs "86" (a reference people use, a Mustang reference, not a Ford reference) pistons I've ever seen. Rock Auto lists the same (cast) "recessed head", with no valve reliefs, replacement pistons for both '86 Mustang and '87 Lincoln Continental.
    1983 Mercury Cougar 3.8L LS
    1981 Mercury Marquis Brougham
    1971 Mustang Fastback
    1974 Pontiac Luxury LeMans
    Jul 2010
    I didn't think the E6 pistons had the dish like the E7's with valve reliefs, but rather a true flat top like the E5's without valve reliefs. Anyway, if they are stock slugs you should see a forward notch, the FORD oval insignia, and a part number on them. You can make these out on the top portion of the face of the pistons in the attached picture of the original factory stock short block in my 85 GT vert.
    HAD
    HAVE
