Results 1 to 7 of 7
    Default Zephyr wagon front suspension
    On my 79 Zephyr wagon with a small block and A/C, I would like to have a lowered stance along with excellent handling. I am installing an AJE front K-member, Mustang GT rack and spindles.
    So, here are my questions:
    1) Which front and rear coil springs will give me a lowered (2" all around) stance?
    2) If I decide to go with coil-overs what front spring rate do you recommend?
    3) What brand/source is a good
    low cost
    coil over?
    4) With a lowered stance what type of rack bushing do I need, off-set or standard?
    Apr 2010
    Portland, Oregon
    SN-95 suspension on stock crossmember. 2.3T (about 100# lighter than the 5.0). -B springs with one coil cut all around.
    FEP User Boxtop78's Avatar
    Jun 2017
    Stockton,California
    4-barrel Mike, I must ask ....love the wheels more info. please brand and size
    Apr 2010
    Portland, Oregon
    Quote Originally Posted by Boxtop78 View Post
    Lincoln LSC. "Made in Italy" by BBS with a FoMoCo engineering number F0LC-1007-CA [/hijack]
    Feb 2009
    Jackson, NJ 08527
    I have a set of those, not nearly as nice finish wise though.
    I have since partially solved my ride height situation in the front. I've purchased a set of AJE coil overs and KYB adjustable struts.
    Once everything is installed, engine, trans, tires and wheels and I will work on adjusting the height in the front and rear.
