Results 1 to 3 of 3
    FEP Member vdubn's Avatar
    May 2017
    Beaverton, Oregon
    Default Dual Hump T5 Trans Crossmember
    I have a like new (less than 100 miles) Anderson 3.5" Power Pipe kit that has the elbow, the K&N Filter, silicon throttle body coupler, and the rubber elbow (complete kit). Has a couple of scratches on the underside, shouldn't be visible once installed.
    SOLD
    I also have a freshly powder coated dual hump T5 transmission crossmember that has brand new Urethane Poly bushings. Its like new.
    $65 for it.
    May 2017
    Beaverton, Oregon
    Power pipe has been sold, I still have the trans crossmember
    May 2017
    Beaverton, Oregon
    Still available
