Results 1 to 9 of 9
    Default 1979 2.3 turbo fuse panel diagram
    Does anyone have a picture of the fuse panel diagram? The one on my fuse panel cover rubbed off and I would like to put a new one in there.
    Name:  fuse loc (1).jpg
    Name:  fuse loc (2).jpg
    closer pic:
    p/n on sticker says D9ZB-14K016-AC.
    1979 turbo Mustang Cobra, original fuse panel cover.
    Name:  fuse loc (3).jpg
    thanks, make sure you don't try to clean it or it will erase everything.
    Name:  FUSE PANEL.png
Size:  27.5 KB I got bored...
    Yah no cleaning the old sticker.
    Tried a long time ago as shown.
    Good work on the copy.
    Ready to print.
    Ink may smear, not durable unless printed face is laminated or something.
    Thermal type label print is more durable. So is vinyl vs paper.
    White printed shipping labels, commonly seen, are peel and stick adhesive backed vinyl or paper.
    Pretty much trash if stuck to one another.
    FedEx Office stores should be able to scan and print thermally on white vinyl or paper sticker stock.
    Best would be reprinting label with a Zebra thermal ribbon printer. It 'melts' ink into paper/vinyl permanently.
    That is what factories, USPS, UPS, FedEx, use to print all types of stickers, part number, shipping labels.
    Those large expensive networked systems can handle production volumes. Custom software.
    Yeah ill figure that out sometime. Are the fuses pretty much the same for all 2.3 turbos for 79 or do they differ with some options like foglights, ac, etc.
    Added aftermarket fogs to mine.
    Did not wire anything to that fuse panel.
    Added another behind glove box.
    Pics is Oct 78 build. EVTM is 79 Mustang/Capri. Print date unknown.
    May have had a running change later in year when pace car appeared with fogs.
    Added fuse or relay somewhere.
    Have no info on that. Others here may.
