Results 1 to 12 of 12
    Default Supercharged 86 GT convertible
    Here are some photos of my 86 GT convert with Weiand supercharger. It has a stock 90 5.0 short block with Crower cam and Edelbrock heads. TCI AOD, 2600 converter, 8.8 position with 3.73 gears.
    2000 Explorer engine with Edelbrock intake, Holley 600, TCI AOD, 3.73 gears, Max Mtr sport roll bar, subframe connectors, and rear control arms. /I]
    Nov 2011
    Alberta, Canada
    Very clean. Great looking car.
    FEP Member brianj's Avatar
    Feb 2012
    Raymond, New Hampshire
    Blog Entries
    2
    It's funny- the longer I look, the more similarities I see in hose and wiring run decisions, although yours is far prettier. Nice car.
    Thanks, yours looks good. I made a new lower support to move the radiator forward about 3/4 inch. Helped make room for a Contour fan.
    What did you do with your hood?
    That car is awesome. Love the very clean looking engine bay. I have the same blower and my engine bay is cleaned up like yours, except I kept the battery up front. I have a 4" cowl hood on mine and clears the air filter by 1/2". I had to run a 6" air cleaner so I could close the hood as the 14" would hit the rear of the hood.
    Bob
    1967 mustang coupe -sold
    1967 cougar GT - sold
    1984 Mustang L 5.0L - Totaled
    1984 Mustang GT 5.0L
    2007 Mustang GT convertible ( wifes car)
    1997 F-350 powerstroke
    USMC Retired 1981-2001
    Jan 2006
    Western MA
    Wow - as previously stated that’s a very clean car.
    1986 SVO Mustang - 1C
    Quote Originally Posted by supercharged347 View Post
    Bob
    I used Scottrods aluminum panels with wiring run on frame channel under them. I used an offset air cleaner base to put in the center of hood (because of the fox body engine offset). I like the air cleaner showing, kind of a "shaker". Then I discovered right before a cruise event that the blower pulley was hitting the hood. Quick fix was another 3" hole. Wish now I had bought a smaller pulley instead. I'm only making 4 pounds of boost and would like to get to 6-8.
    Feb 2012
    Blog Entries
    2
    Sorry for the delay- some minor trimming on the hood, a fabricated panel to make the air cleaner seal to the hood, and a factory '83 GT hood scoop made functional. I switched to one of the cheap Autozone filter top air cleaners to give the airflow a better path to the carb.
    Looks like your blower pulley cleared the hood. What size pulley and how much boost does it make?
    Feb 2012
    Blog Entries
    2
    It makes 7 pounds at 6000, and I have no idea on the size. I can measure it up. It came used with it, and everything worked as it sat, so I never bothered checking. I just cowboy'd it together and crossed my fingers.
    Well, I pulled the supercharger off and installed an RPM air gap manifold and Holley 600. I just bought an 83 scoop to finish out the hood.
    The car is for sale in the classified forum.
    Quote Originally Posted by Geezerstang View Post
