Results 1 to 15 of 15
    Default Looking for this part above the mirror
    Where can I source this trim part (see red circled item in picture) or what is the official part name on this piece to search the internet for a new one? I need a drivers side piece. Picture is of the passenger side. I don't need the actual window channel seal, but the hard plastic trim piece.
    I've searched a few part sources online and have been coming up empty on finding a new one.
    This is on a 1983 convertible.
    Thanks!
    I believe this is the part. Right side, just sold on eBay. Manufacturer Part Number: E1ZZ-6620476-B
    On the 87-88 cougar birds they are called "wind splitters"
    Thank you,
    Get someone with a 3d printer to make some?
    My 85 T top has those as well. Does anyone know if early t top cars also got these along with convertible? I'm planning a t top conversion on my Capri and have the roof and door glass... still collecting the little things.
    My 85 t-top Capri has those, and would like to replace them as well
    These trim pieces were added to the convertibles and the T-top cars to cover up the cut window frames due to the modifications for the convertible and T-tops. The original plastic trim pieces were glue into the rubber gaskets and came as one unit. Obviously the plastic part is separate, but you get the idea.
    Here are pictures of the NOS OEM ones I have for my 82 RS.
    Front side
    Name:  2018-10-22 11.27.45.jpg
    Back side
    Name:  2018-10-22 11.27.38.jpg
    Feb 2018
    Saskatchewan, Canada
    I am also in need of a drivers side one for my 84.5 t-top. Question though, do you have to use these or can they be replaced or modified with something else?
    Here is my old one. Back side plastic to mount it is broke. Also second pic is of my drivers side door where mirror mounts. Looks like it was hit and bent.
    Attachment 124652
    Attachment 124653
    Attachment 124654
    This is not pointed at any one person...
    No buying or selling parts outside of the classifieds. Do not reply to this post that you have or might have parts for sale. do not ask if anyone has any parts for sale. Use the classifieds. Thanks.
    Feb 2018
    Are these the same as what I'm looking for? Found them at foxresto.
    https://www.foxresto.com/1981-86-Con...-p/1783013.htm
    Yes, those are the seals/weatherstripping that is needed at the front of the doors for both T-top and Convertible models. Those are the reproductions of the parts I pictured above just without the hard plastic trim piece that goes around the mirror.
    Feb 2018
    Ok thanks Trey, did not realize that that was just the rubber. Looked different where the plastic piece goes.
    Cant believe no one makes that piece. You would think it be a pretty common.
    Mustangs
    84.5 Gt T-top
    85 Gt
    I am surprised that someone hasn't reproduced them yet either. I have consider doing it myself, since I have the NOS set to work off of. Unfortunately I just haven't had the time to even try to work on that nor any of the other parts I want to replicate. Maybe someday.
    Default 3d printing becoming a bit more accessible and affordable to make a part
    Noticed today a local library offers use of 3d scanner to create a 3d printer .stl file needed to make an item.
    With a .stl file can schedule a print of a item, like the trim piece, in house.
    The HS is next door to the library and HS students are involved in operating the print machines for the public.
    Print price is per gram of plastic or something and have an object size limit of 12" or so.
    They also have a small cnc machine for soft items.
