Results 1 to 19 of 19
    Nov 2014
    Grand Rapids, Mi
    Default Dying interior panels
    Figured before they go back in, it’s time to spray them. These big pieces are actually quite a pain, due to their size. First thing I did was take them into the tub, and thoroughly wash them with dawn dish soap, rinse, then wash again. From there I sprayed them with a wax and grease remover, then wiped them down twice with denatured alcohol, and did two light coats of an adhesion promoter and added some color. So far, so good. Name:  4E3AAD98-D736-494A-BF10-A8C5064224E5.jpg
Size:  80.0 KBName:  363A60C4-0225-4208-BA56-522E1F2F04B3.jpg
    Barboursville, WV
    That looks great! I need to do this to my 79 cobra.
    Grand Rapids, MI
    Looks great. Text me your address and I'll bring over some of the faded interior plastics from my wagon for you to do.
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
    Wow, that looks great!
    What wax and grease remover did you use?
    TIA! :-)
    Btw, Porno Red interiors rule! ;-)
    So that’s an 85/86 interior. What color SEM paint did you use?
    Looks great!
    Nov 2014
    Grand Rapids, Mi
    They’re out of an 83. Believe it’s color code D, medium red. The big panels took almost a can a piece.
    Nov 2014
    Grand Rapids, Mi
    The wax and grease remover was by 3M.
    Jan 2003
    Muskegon (Power Tour stop!)MI
    Can you snap a pic of the can? I have a few pieces for my 83 that need to be re sprayed.
    Thanks, Zen
    '86 GT - weekend driver
    '86 Capri 5.0
    '86 Turbo Coupe
    '17 Mustang GT
    '23 BRONCO
    Nov 2014
    Grand Rapids, Mi
    Quote Originally Posted by ddx77 View Post
    Really looks great!
    Do they need to be clear coated afterwards?
    No clear coat needed.
    Which brings me to my next dilemma. A saggy headliner. The interior literally goes around the headliner. Researching headliners here, I believe I can fix it myself. But, Trey just recently told someone “roadworthy first, roadworthy, roadworthy, roadworthy”. So with the liner out, the black roof with the pretty aluminum rivets, might just have to get me by until winter. Besides, the way it tucks into the T top channel, looks to be a pita. Name:  F88456E7-F33F-4FB9-9F2D-50077A1EDFDB.jpg
Size:  96.2 KBName:  DC2B71AA-B6AF-45DC-B808-FCADB25734ED.jpg
    Nice results!
    Default Henry Ford official charcoal
    https://www.kingsford.com/country/about-us/
    My black 1/4 panel trim, plastic flat top ledge at the side windows, has started to crumble away.
    Hole appeared while cleaning ledge area with towel and cleaner.
    Just like a metal rust out. Hole kept getting bigger the more it was pushed on.
    Now have to reinforce and repair the area with metal or plastic and filler.
    These parts are getting old and can lose integrity after 40 years of UV, heat/cold cycles.
    Like dash pads do, except no cracks but total failure.
    Other areas are fine and still flexible.
    Jul 2016
    Duncannon PA
    You cleaned yours exactly as i did and I had zero issues with fisheyes and mine was done several years ago. Looks awesome btw
    Thanks!
    Also, thanks for the picture of the can.
    Dang that looks good
    Mar 2017
    middleboro massachusetts
    how far did one can stretch?i thought I read at one time that it takes a lot of paint to cover? I gotta do my interior soon.mine is gray though
    That looks super great! Looks like it’s just what the Dr ordered. My 1986GT has a red interior too. So many don’t like them but when the car is black I think it goes.
    In my car I customized a bunch of stuff. Black behind and above the door trim in the lock area, went with black carpet, did a stretched black leather over the dash pad, etc.
    Jul 2016
    Duncannon PA
    Quote Originally Posted by kfxmatt View Post
    I sprayed mine with a gun and only used half a pint to do every piece of the interior with two coats of charcoal grey.
