Results 1 to 4 of 4
    FEP Member James2488's Avatar
    Des Moines, Iowa
    Default 1985 GT Electrical Help
    Trying to clean up my 85 gt.
    I've got a couple of connectors that I'm looking for. I'm looking for the brake switch connector and the red connector that plus into the heater control (a/c and rear defrost car). I'm also trying to figure out where the black/tan wire from the alternator. That wire is all that I have.
    I'm also looking for the clip that holds the ring on the steering column to the column.
    Sent from my LG-US996 using Tapatalk
    2015 F350 6.7 CCLB Platinum
    2008 Taurus 3.5
    1997 F250 7.3 RCLB ZF5
    1985 Mustang GT T-tops 5.0/T5
    1968 Pontiac LeMans 400/ST-300
    Jan 2005
    Cordova, TN
    Hmm, I thought this would be easy, but google is striking out.
    I’ll look at mine tonight
    These might not help much- the wiring diagrams in the sticky can help you identify the full circuit using the color codes.
