Results 1 to 15 of 15
    Default 79 capri RS , 5.0
    Is anyone restoring a 79 capri RS? My question is do restore to stock or modify to your liking?Name:  IMG_1850.jpg
Size:  129.8 KBName:  Capri rs.jpg
    I vote to modify it to your liking, just be sure not to go over board and butcher it up. Restore the body and trim to look like it did new. Add a three peice spoiler. Then a nice 5.0 roller with a mild cam, heads intake and carb, 8.8 axle and gears and a t-5. That’s me though.
    That black and orange color combination is very cool it’s going to look nice once it’s all cleaned up
    Sep 2008
    Greenwood, IN
    Your car = whatever you please I would try to add the Saleen/MacLaren look to it....add a lower valence to the front, side skirts and the rear spats or valence.
    Jason Smith
    MCA #65481
    '82 Capri RS Resto-Mod
    '05 S-281 Mineral Grey
    Feb 2009
    Snohomish, Wa
    X2 on the 3 piece spoiler.
    Dave
    1983 Capri RS Turbo
    1981 Black Magic 400 c6
    93 F-250 351 5sp 4x4
    -1 on the spoiler. As great as they look, it doesn't belong on a 79. At this point it is more unique and cool without it.
    That said, it's your car to play with. Do what makes you happy. Just don't drill that nice clean flat hatch. :P
    FEP Senior Member E2ZZGLX's Avatar
    Jan 2012
    Broomfield Colorado
    Quote Originally Posted by BLUECRAPI View Post
    I would have to agree...unique car keep it that way.
    Current keepers...
    77 Cobra II
    80 Bobcat Sport
    82 GT-first new car is back home!
    85 ASC Coupe
    86 SVO
    86 Escort GT
    88 Ranger GT
    TOTALLY agree with Lowetlx! Maybe because that's exactly what I'm doing. I added an '83-'84 front end though, to finish it off.
    I like the the Black/Orange color combo, but since you have a black car, If you decide to repaint it, the Grey/Charcoal RS Striping looks super sweet too! Make it what you want, but just keep it and do it (Don't take 30 plus years to do it like I did though)!
    Sep 2010
    Lexington, MA
    Back in the '90s, a kid that I went to school with bought one exactly like that; '79 RS, Black/Orange, Red interior, 5.0/4spd. I think it had a Sunroof too. Kid sold is almost immediately to another kid who blew the engine and installed a '74 302 from a Torino. Another kid bought it, and Aero-ed it out 2 years ago, the kid stripped it out, and sent what was left to the crusher. Sad.
    Where do I get interior parts for this car does anyone know a good spot to look?
    Quote Originally Posted by Joe caetano View Post
    Interior parts for the Capri are the same as the Mustang. The door panels are specific to the 79 and early 80 models due to the low door handle placement.
    The rear inner quarter panels are essentially the same from 79-86, although I believe the 79-82 are the same and there is a slight change in the area under the rear quarter glass so the 83-86 are different. They will interchange, but keep that in mind.
    Center consoles are the same and dash is essentially the same from 79-86, again with the caveat that stereo opening changed on the later models. Not a big deal if you want an aftermarket stereo, but can be if you want to stay stock.
    The carpet, seat materials, etc. are generally reproduced although they may not be a 100% match to your 79 model. Good Luck!
    Has anyone put a 9 inch rearend in a capri
    not personally, but I've known a few that did...there are kits to either mod the housing to fit the car or you can mod both the car and housing with a 4 link or some other form of aftermarket suspension.
    The other option is to install one from Strange or Moser that are already built to fit the car...they're kinda costly.
    Realistically, an 8.8 will handle pretty much whatever you want to throw at it unless that involves somewhere north of 1K hp and I wanna say it's a little lighter than a 9
    The Ford 9 inch is a great rear end that is used in a ton of different vehicles both stock and modified. Unless you are pushing a TON of power and using slicks, there is little benefit to a 9 inch over the 8.8 in most cases. If you need/want to change gear ratio often that would be a good reason. If you need to eliminate the C clip setup for autocrossing or road racing that could be another. Otherwise the 8.8 can handle virtually anything the 9" can. Besides technically the 8.8 design is more efficient than the 9 inch design due to the pinion being placed so low on the ring gear in the 9 inch setup.
    If you are doing a custom suspension then swapping a 9 inch into a Fox can be pretty easy and straight forward. If you plan on running the stock style suspension setup on the 9 inch, then you will most likely want a custom build housing just as suggested above from Moser, Strange, Currie, or others. Good Luck!
