What to keep and what to pitch form the 2.3 notch like can i reuse the 2.3 harness
The harness can be made to work by lengthening, shortening or repositioning wires.
What transmission crossmemer do i use
I would look for a dual hump crossmember so you can run dual exhaust.
Can i reuse the AOD flex plate
Probably not. It depends on the bellhousing on the C4. 68 Mustangs used a 157 tooth flexplate where AODs use a 164 tooth flexplate. Either way since your engine is an 85 it will have a 50oz imbalance and the flexplate needs to match that balance.
The throttle cable may not work, you may need a larger capacity radiator along with all the radiator hoses. You will also have to figure out the fuel system.
