Results 1 to 3 of 3
    Default How long are rear brake hard lines?
    I am doing the cobra brake conversion and was curious what length brake lines I should buy. I figure I will just bend up some new lines vs cutting and flaring the ends of the existing ones. 86 car
    Todd
    I used 40” sticks. The left side I had about 10” to cut off but the right side being longer wasn’t as much waste. I would go with the adapters in your situation and you won’t have to flare anything.
    Grand Rapids, MI
    Are you talking about the lines on the axle or going back to the rear axle? If you are like me and hate bending brake line you could buy preformed lines from somebody like LMR.
    https://lmr.com/item/SVE-1078C/Drum-...-Mustang-86-93
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
