I am thinking about upgrading to the LA3 and browntops for our 84 SVO.
I have a set of E5ZE A38 brown-top injectors, and a set of E6TE A38 brown-top injectors. Which, if either of these, are the correct ones?
What is the difference in them?
Ron
Ron
I never seem to get the nut that holds the steering wheel fixed
Are those the engineering numbers stamped on them? My notes say low-impedance, "Brown" - Motorcraft CM-4351 or Ford E5ZZ-9F593-A engineering number
E5ZE A1A. I think they are likely the same part with the second set just being an engineering number for a tbird or Merkur.
Thanks for your input jacquejp.
I am having trouble finding much info about these two sets online.
Ron
Anybody else out there in foureyeland have definite info about these injectors?
What I want to know is if either of these injectors will give proper performance with an LA3 ECU that I may install in my 84 SVO.
Ron
E5ZE- A2B will work also, svc part # E5ZZ-9F593-A
also E5ZE- B9A , svc part # E7SZ-9F593-A
'87 Turbo Coupe - 660 mile original
'86 Turbo Coupe - 74k mile stripper
-In a word, yes.
Thanks.....I appreciate the help!
Ron
Just make sure you go to the bigger VAM at the same time if you haven't already. Lesson learned.
