Results 1 to 1 of 1
    FEP Member vdubn's Avatar
    May 2017
    Beaverton, Oregon
    Default Auto Meter Ultra Lite Oil Pressure and Water Temp Gauges and Center Console Bezel
    I bought these from LMR just a couple months ago, for about $170. These gauges are both electronic, not mechanical gauges.
    Fit perfectly in the 4 eye Center console, and should fit all of the 1979 to 1986 cars as is.
    SOLD
    Attachment 120375
