Results 1 to 8 of 8
    Default Correct Paint For Charcoal Hood Inlay
    Hello, I decided to repaint the gray hood insert on my car. The car is black and the trim is charcoal gray. I’d like some feedback as to the correct paint color/texture needed. I’ve heard that sem charcoal 39153 is the closest match for he color. Is this correct? Also, is it supposed to have a matte or flat finish? I’m pretty sure it’s not gloss.
    Same question for the “GT” emblem.
    Any help from someone who has done this before would be greatly appreciated. I would like to keep the car as stock looking as possible.
    Thanks,
    Matt
    Previous:
    79 Notchback
    86 GT
    93 GT Convertible
    Current:
    86 GT Convertible
    Jul 2010
    Houston (Clear Lake), Texas
    The SEM paint is a little light in shade IMHO. It's also an interior trim paint, so it won't have the durability and/or longevity. The hood stripe is a large area so the rattle can option is probably not the best. To answer your question, the charcoal accent trim is a satin finish, which is close to a matte finish. Because my 1985 GT vert has the lower 2 tone accent I chose to but the stencil and paint the hood stripe with the rest of the car. I had given the original owner and long time friend some parts in 87 from a very low mileage 86 GT vert that was totaled...I was getting other parts for my then 82 GT. He put them away in covered storage and they were still intact and like new when he sold me the 85 GT back in 2011. I did alot of research and ended up having Sherwin Williams automotive special mix a commercial product...Coca Cola, Pepsi, Budweiser, etc. utilize it...to match the trim from the 86. My painter sprayed a couple test shots until we had it very close to the color shade and finish. I also had pictures he gave me to somewhat confirm the color shade on the accent trim from back in 1985 when the car got its first wash. If interested, you can do a search and find the product and/or mix for it. I will caution you though it is not the most economical solution but I can tell you it still looks like the day I picked it up from the paint shop back then. The picture below was taken the day I got the car back from paint. I had to install all the trim back on the car and then take it back so he could buff the white field color.
    HAD
    HAVE
    Nothing against the SEM paint as it is good quality and matches pretty well in many cases, but in an exterior situation it does not hold up long term, especially on Daily Drivers or cars that aren't stored indoors.
    The correct color code for the 85/86 Dark Charcoal Grey Trim paint should be PPG #DDL 33717. Your local auto paint supplier should be able to use that code to mix the proper color. I will tell you that you want to test and verify. I had an issue with the mix in one brand by my supplier where the color had too much violet in the mix and had a purple hue when sprayed. In a difference brand it was spot on.
    In regards to the sheen, as mentioned the sheen should be a Satin/Matte finish. In my experience I have found flattening the clear to a 50-60% gloss usually works well. Some suppliers offer premixed Satin/Matte/Flat clears. I personally prefer to make my own with flattening agent in regular clear as that gives me the most flexibility. Hope that helps and good luck!
    I masked my hood by hand and used the SEM cans. It has held up well for about 6 1/2 years and still looks great. My car is garaged all of the time, and is a "fair weather" driver. I have some pics in my albums.
    - CA car, 5.0 w/5 speed
    I have a test spray out from Trey for my 85 Saleen. The charcoal is spot on.
    All done!Name:  0FC897ED-2A4C-4DAD-89F7-BF7CFB71BB0B.jpg
    Previous:
    79 Notchback
    86 GT
    93 GT Convertible
    Current:
    86 GT Convertible
    Looks great!
    Thanks so much!
    Previous:
    79 Notchback
    86 GT
    93 GT Convertible
    Current:
    86 GT Convertible
