Results 1 to 4 of 4
    FEP Senior Member 86GTdriver's Avatar
    May 2007
    Norfolk, VA (again)
    Question Window Motor Mount Hardware ?s
    So I was wondering if one can use a nut/bolt to mount the window door motors to the interior frame of the doors as opposted to using rivets. I'm about to drill out the rivets to replace the motor and would like to know what my options are, including width/length of nut/bolt combo and grade. Can anyone help me out? I couldn't find anything searching this topic, but I'm sure it's been done before.
    Also, what's the best way to support the window once the motor is ready to be removed without it falling into the door. Can't be breaking any T-top glass afterall.
    '86 Mustang GT T-Top, well... I got the subframes primed and painted now.
    '96 Mustang Cobra 302rwhp 296rwtq, Sold and missed
    '11 Mustang GT/CS, Traded and will be missed
    '13 Taurus SHO, Performance Pack, Windstorm CAI, 160* t-stat, 3 bar BAP, Livernois V10 tune
    Jul 2016
    Duncannon PA
    Yes you can use bolts and nuts. Iirc I used button head bolts. They have lower profile heads. They are either 1/4" or 5/16" I can't remember. Length is very short only 1/2 or 3/4 inch. I use nylon lock nuts so nothing can vibrate loose. I also use the same things for power lock actuators.
    Portland Oregon
    What year car do you have? On my 86, you can remove the window motor without having to remove the regulator from the car. It should just unbolt with a 10mm socket.
    As for holding the window up, if the regulator is installed, I have used a small block of 2x4 to wedge it up. If the regulator is out, I have gently lowered the glass into the door.
    67 Mustang Coupe
    96 Tangerine GT
    86 Saleen #179
    May 2007
    Norfolk, VA (again)
    Quote Originally Posted by Tigger View Post
    I've an '86, as per my handle.
