Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 105
Thread: 1986 LTD Wagon
  1. #51
    see below
  2. #52
    And know for your viewing pleasure:-
    https://youtu.be/YHimia_Fxzs
    https://www.youtube.com/watch?v=YHim...WNv9TjGzdb3XBQ
    At 1.13, 2.58, 3.56 and 5.04
    Whaddaya see?
  3. #53
    I remember the song.... I don’t remember the video. There goes that news wagon again.
  4. #54
    Jul 2009
    Chicago, south subs
    That last shot; I don't recall ever seeing a rear wiper, didn't know it was an option.
  5. #55
    Jul 2009
    Chicago, south subs
    Car started idling rough again. Found another broken vacuum line. It was an elbow right behind the alternator at the front of the passenger side valve cover.
  6. #56
    Jul 2009
    Chicago, south subs
    More on the rough idle; vacuum modulator diaphragm failed, creating another vacuum leak. I wondered where my trans fluid was going? (no leak). Side note: parts stores do not stock these anymore. Had to order it.
  7. #57
    Jul 2009
    Chicago, south subs
    The weather was decent today. Got the vacuum modulator installed. The new one has an adjustment screw, the old one didn't. I left it alone(the screw), it drives fine. There's a small rod that inserts into the modulator, it fell out when I took out the old one. It inserted the same into the new modulator, so I didn't adjust it.
  8. #58
    nice wagon. i got a 86 just like yours same colorsName:  20191210_094700.jpg
  9. #59
    Jul 2009
    Chicago, south subs
    Nice.
  10. #60
    Jul 2009
    Chicago, south subs
    Just replaced the second battery in this car, this year. Couldn't find the correct size battery the first 2 times, so got a similar size, slightly wider(3/4"?). Both times it slid further back in the tray while driving and the alternator fan bit into it. First time, Advance auto replaced it for free, this time it's on me. But this time I did finally find the correct size so it won't happen again. It's not an issue in the Fairmont with the 5.0, the alternator is nowhere near close to the battery. Just in this car with the 3.8.
  11. #61
    Yeah the battery is a bit close to the alt fan. Damn 3.8s lol. Can't wait to v8 swap it
  12. #62
    Jul 2009
    Chicago, south subs
    Quote Originally Posted by 87_notchfox View Post
    LOL, yeah.
  13. #63
  14. #64
    Jul 2009
    Chicago, south subs
    very nice
    Quote Originally Posted by Rusty Bouqet View Post
    I highly recommend a V8...
    Name:  2020-06-14 17.04.04.jpg
    Name:  2020-06-14 17.04.26.jpg
  15. #65
    Jul 2009
    Chicago, south subs
    Update on the battery vs. alternator situation: The acid burned a hole in the top of the vapor canister creating a large vacuum leak . I noticed that my air conditioning would keep switching from vent to defrost whenever I pressed the accelerator. It was working previous to this so I searched for a leak and found the hole in the canister.
  16. #66
    I thought about another 32v swap. Coyote now not the old engines
  17. #67
    Jul 2009
    Chicago, south subs
    Another thread I started because of a fuel pump issue I had with the wagon: http://vb.foureyedpride.com/showthre...-pump-question
  18. #68
    Jul 2009
    Chicago, south subs
    This car had air shocks on it when I bought it. It also sagged in the rear, I believe the previous owner installed them in an attempt to correct that. I replaced the coil springs a while ago which helped the sag situation, but the ride still felt extremely soft. Yesterday I removed the air shocks and installed conventional shocks. I also installed Air-Lift bags inside the springs. They don't affect ride height, but they do make the ride firmer without being harsh. I also intend to tow a small fishing boat trailer and I wanted a little more capacity for that.
  19. #69
    Jul 2009
    Chicago, south subs
    The car(engine) developed a maddening squeak/chirp noise in the last few months. Could not locate the source. Changed the tensioner pulley, no dice. Had a spare alternator, so I swapped it in. Nope. Water pump is new(er). PS pump is new(er). So I just watched it while running and i noticed the PS pulley is slightly mis-aligned with the other pulleys, causing the belt to rub on the inner edge of the water pump pulley. Like the ps pulley was installed too far (by me). So I used my puller to move the pulley out a bit and now the belt rides right in the center of the water pump pulley. No more squeak/chirp. Didn't realize the PS pulley could be installed too far.
  20. #70
    Jul 2009
    Chicago, south subs
    Time for new brakes and struts. '87+ upgrade for the brakes, Tokiko blues for the struts. I gotta get on a more regular inspection schedule. This could've been bad, I got lucky.
Size:  94.0 KBName:  P1380420a.JPG
  21. #71
    Jul 2009
    Chicago, south subs
    BTW, the brakes were working fine, but that hose could have popped at any time.
  22. #72
    Good choice on the dampeners. I love mine!
  23. #73
    Jul 2009
    Chicago, south subs
    Toe is way off with the new spindles. Def gonna have to adjust on it to make it drivable. Then to a shop for an accurate alignment.
    edit: I did a driveway string style calibration(lol) on the toe issue. I must have got pretty close, drives much better.
  24. #74
    Jul 2009
    Chicago, south subs
    Got the alignment done at the shop. Drives really nice now. Also, I installed new rear shocks. Passenger side was blown out, as was the pass side front strut. So glad all this is done. But I noticed the tailpipe is rotted where it comes out of the muffler. Never ends.
  25. #75
    FEP User
    Aug 2013
    Lawrence Swamp. Amherst, MA
    thnx for da thread !
    Just got one like it after long search (well w a y more clapped out than ur beauty). Maroon '85 3.8, 3 speed auto(seems pump leaks bad) no exhaust, both sides frnt floor bds 'gone' (no windshield gasket due to rot, missing driver's side ext chrome strip).
    What's in the future for ur rig?
    5 Qs asa new guy...
    Any line on ext/int trim (new as after mrkt) or a guy w/a lot at his junk yard, etc?
    Do U know if the 4.2 head is a performance upgrade (MPGs'n pep)
    What rear end do we have?
    for Auto - C5 only (some 1 said C3 in some too)?
    Ur motor (my) hasa SBF bell mount up (I seek AOD or 4r70w).
    Chad
    Seeking: fox station wagon int/ext trim (esp LTD/Marquis)
    Retire/restore ol Bronk to daughter
    chrlsful@aol.com
