Results 1 to 15 of 15
    Default Ziebart coating removal engine bay
    My 86 Capri was treated to the Ziebart service which did the job over the past 32 years. Part of the service was to cover the inside of the engine bay with some kind of undercoating, so it looks pretty bad. However, I want to clean up my engine bay and was wondering if anyone had luck removing the undercoating without damaging the paint underneath?
    I was thinking about using PB Blaster to try to get under it and then a plastic scraper to scrape it off.
    Any advice?
    St. Louis, MO.
    I've heard that a high pressure washer using hot water can blast it off without damage to the paint.
    Chemically you could try this stuff.....? https://www.sherwin-williams.com/hom...og/peel-away-7
    Scotty
    Past Pony's.....
    Jul 2016
    Duncannon PA
    If youre careful enough a propane torch will soften it and scrape it off as you go. I did the whole underside of a car that way. Then I used lacquer thinner to clean it the rest of the way. It cleaned up fairly easy leaving the factory red oxide primer in tact. Not a fast way but very thorough
    Bug and tar remover, scrape with an old credit card
    Heat gun instead of torch.
    Thanks for the suggestions! I spent some time on it this weekend and found that 'Goof-off' spray with a stiff nylon brush did a pretty good job on it. The coating on the fender itself where it bolts under the hood came off pretty easily, but the stuff on the inside of the engine bay was a lot more difficult. I let the Goof off sit on the thick stuff for a while and it loosened it up, but I had to scrape a lot of it off before I could really get the goof-off to work.
    I used a plastic scraper for the thick stuff and it worked pretty well. I waxed the areas that I had cleaned up to make sure I sealed the paint.
    I read on another forum that someone suggested denatured mineral spirits. I'm going to try that, too..
    I'll try the heat gun tonight on the really tough stuff. I have a LONG way to go!
    FEP Senior Member 83GTJIM's Avatar
    Apr 2012
    Springfield MO
    I believe one of the members here (Bob) removed the undercoating from his entire car.
    MCA #110307
    "Saved" 25k mi 83 GT - http://vb.foureyedpride.com/showthre...ght=Wrecked+GT
    83 GT T Top
    83 GT Convt
    84 20th Anniversary T Top GT350 SOLD 11/17
    84 GT Convt SOLD 08/18
    Sep 2008
    Greenwood, IN
    WD-40 and a plastic scraper and brushes. One of my friends (and member here) removed the sludge from a ~2k mile '86 GT last year and swears by it. A friend of mine also removed the sludge this way from the '92 Calypso LX I sold him late last year.
    Jason Smith
    MCA #65481
    '82 Capri RS Resto-Mod
    '05 S-281 Mineral Grey
    Sep 2008
    HILLBILLY HOLLYWOOD, Tennesse
    Oven cleaner
    Mayonnaise. Let it sit and Yes it works!
    www.musclecardeals.com
    Sep 2008
    Greenwood, IN
    Quote Originally Posted by vintageracer View Post
    Oven cleaner
    Yeah...that will make you think twice before using mayonnaise on your next ham & cheese over Miracle Whip
    Jason Smith
    MCA #65481
    Sep 2008
    That's why "I" only use Miracle Whip for my samiches!
    Yuck!!
    OK, so now I'm going to have to try mayo. Any particular brand work any better? You know, down in the South, we use Dukes. All others are just uncivilized.
    Sep 2008
    Quote Originally Posted by 86McLarenCapri View Post
    YYou know, down in the South, we use Dukes. All others are just uncivilized.
    South??? Norfolk looks awful far "North".
    What side of the Mason Dixon line is Norfolk located on???
    Just checked.
    Looks like you made it after all!!!
    FEP Senior Member rodster's Avatar
    Feb 2006
    Allentown, PA
    Had the same undercoating on my 83 TBird. Decided to degrease and low pressure wash the engine bay many years back and after letting the foaming engine degreaser soak for awhile, when I washed it off, some of the undercoating came off too! Might want to give that a try too.
    I've also had luck with WD40. Removing undercoating, not on sandwiches.
    FEP Member gry84GT's Avatar
    Feb 2009
    Mt Arlington , new jersey
    brake cleaner...worked for me
    'BP 347, Weiand 8124, 1.6rr, 4180, shorty headers, 2:1 3" exhaust, 7.5" 3.73,
    http://s875.photobucket.com/user/pet...?sort=3&page=1
