Results 1 to 1 of 1
    FEP Supporter vdubn's Avatar
    May 2017
    Beaverton, Oregon
    Default SBF Motor Mounts for AJE Subframe, with ARP Bolts
    SOLD
    I have an almost new set of Small Block Ford solid engine mounts to bolt to an AJE K member. I paid $70 plus the ARP bolts were $30.
    Selling for $55 shipped anywhere within the lower 48 states.
