Results 1 to 7 of 7
    Default LED tail lights for an 85 GT
    I was wondering if the LED tail lights advertised for the 88-93's will fit on my 85 GT. And if so, would it be a "plug-n-play" or will there need to be some wiring modifications to the harness? Thanks for any information on this.
    Jul 2016
    Duncannon PA
    They should be the same wiring wise but I don't recall about the bolting in part.
    Well, if you think about it....
    The 93 Cobra used the 85/86 SVO tail lights which were just striped 84 LX/GT tail lights.
    FEP Senior Member 854vragtop's Avatar
    Dec 2006
    Greensboro, NC
    I've had excellent luck with these 1157R Sylvania Zevo LED's in the back of my '85 GT. No issues with them affecting the front turn signals. No issue with them affecting the dash turn signal lights. No need for load resistors. The warning light does come on in the console alert center. I took pictures to compare and they are definitely brighter as tail lights and brake lights. They are do not directly send any light aft (the black lens "stripe" is in the way anyway). The light all reflects off the housing reflector, but it's still brighter in every way. They go on and off immediately instead of the slower ramp up and down time as incandescents. Plug BOTH bulbs into the sockets before seeing if they're working. They won't work with one LED plugged in and one incandescent 1157 plugged into the other socket.
    Get the red bulbs. The color is a much richer red. Buy a pair at Autozone and test them out. Easy to take back if you're not happy. I was very happy with mine.
    https://www.amazon.com/SYLVANIA-ZEVO.../dp/B01A77TV4Q
    My photo website:
    http://www.twilightphoto.com/
    Yeah I realize that but for some reason they don't include those cross over applications in their listings, that's why I decided to ask.
    Keep in mind that the housings (actual bolt in light socket part) are the same 83-93. The Lenses are 83-86, 87-93 LX, and 87-93 GT but all will physically interchange.
    The issue with any "Plug & Play LED setups" might be that IIRC the tail light bulbs and sockets changed in 1988 going from an 1157 (79-87) to a 3157 (88-93) so if the setup is designed for the majority of Aero cars, then the socket is most likely different. Not a huge deal to swap sockets out, but obviously will not be a plug in.
    Thanks Trey, that's the info I was looking for. I thought that was the case but without any first hand experience with 87-up foxbodys, confusing and sometimes conflicting listings were all I had to go on. Thanks to everyone for their input.
