I could use some help as I’m about at my wits end.
My 84 GT is back to its random electrical issue where sometimes when you turn the key, nothing happens except for some weird electrical clicks behind the dash. It doesn’t seem to try and engage the starter or solenoid. It’s almost like a new car with an almost completely dead battery where things on the dash flicker but nothing happens.
For the most part, I usually don’t have any issue, but when when it acts up, it does it at the most in opportune times and there is no rhyme or reason to it.
The car has a new key switch, ignition switch, starter solenoid, ignition module and so forth. When I did the EFI upgrade, I had to fix a bunch of wiring and when I did, I added additional grounds and made sure all repaired connections were clean and tight. The battery cables are also fairly new and tight.
Any ideas? I really don’t want to have to replace random things to cure this issue.
