Results 1 to 10 of 10
    FEP Power Member grtskydog's Avatar
    Sep 2003
    Carolina Beach, NC
    Default Sail Panel WTF (a cautionary tale)
    I recently removed all my interior trim to paint and restore. While I was at it, I thought I'd remove the sail panels and sand/paint them as well (they need it). When I removed the driver's side, none, repeat, none of the nuts came off the little studs mounted to the sail panel. Half of the studs broke the mounting bosses off the panel as they turned, the other half unscrewed themselves from the bosses without damage. I'm posting this as a cautionary tale to others who wish to remove 30+ year-old panels. If you carefully turn the nuts, you may save all the bosses from destruction, and if you're lucky the nuts will come off the studs like they are supposed to. I am going to hit the pass. side nuts with Silikroil in hopes that it will allow the nuts to turn on the studs and not rip them out of the sail panel end. BE CAREFUL if you decide to pull your sail panels!
    Ed
    "The Dude abides."
    Sep 2003
    Carolina Beach, NC
    Here's the deal.
    Ed
    "The Dude abides."
    FEP Member brianj's Avatar
    Feb 2012
    Raymond, New Hampshire
    Blog Entries
    2
    Yeah, that's about the luck I had. Fortunately, only a couple broke, every other one unscrewed the entire stud.
    Pretty standard issue with most sail panels these days unfortunately.
    A pair of needle nose vice grips on the studs will get them off the car. Then either some urethane or epoxy adhesive/glue will set them back into the sail panels just fine. The same adhesive/glue will often glue the broken mounts back onto the sail panels too. Just be sure to add a nice ring around the base of the mounts to help secure them in place. Good Luck!
    with the epoxy the mounts will be stronger. I have had the same issue with several cars. sometimes if you have some one push on the sail panel on the out side to relieve the pressure as you brake the nuts free it helps.
    Sep 2003
    Carolina Beach, NC
    Thanks guys. My plan was to epoxy the broken bosses in and call it good. I won't be pulling the other panel. Easier to mask/paint it on the car.
    Ed
    "The Dude abides."
    Yep. Pain in the ass. The same issue goes for good scoops and rear wings.
    '79 Indy pace car T-top
    '81 Cobra
    '81 Cobra T-top
    '82 Mustang GT T-top
    '87 Corvette
    '10 Mustang GT Convertible
    '17 F250
    '17 Landrover Discovery Sport
    Mar 2017
    middleboro massachusetts
    Quote Originally Posted by grtskydog View Post
    Here's the deal.
    same thing happened when i removed mine also.in this photo,what is the large rubber grommet at the top with the whole in it?i noticed im missing one on the passenger side.can these be bought?
    Sep 2003
    Carolina Beach, NC
    Not sure. Looks like some sort of vibration snubber.
    I wish I'd asked about this prior to messing one up. Maybe this thread will cause some to re-think and just work on them on the car.
    I'll be on the lookout at the pick-n-pull. I've become a four-eye "rare parts" collector lately.
    Ed
    "The Dude abides."
    Quote Originally Posted by kfxmatt View Post
    I am not 100%, but the grommet in question is a plug. I believe the hole that is plugged up is used in manufacturing to either hang the quarter panel or help hold it before the uni-body is welded. I have not seen a replacement, but I also haven't looked in awhile, so it's possible. I have found regular plugs that can work and I have also used some quality urethane sealant to plug the opening too.
    I admit they are a pain when the studs pull out or the mounts break off. I personally have found that a small cordless drill or impact work best for removal. Doesn't guarantee you won't have the same problems, but I use a 12V Milwaukee drill or impact (often the impact) and the seems to help pop the nut loose from the studs in most cases. Using a regular ratchet seems to more often than not pull the stud out or break the mounts at least in my case, but then again it could be operator error too on my part!
