Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 92
  1. #26
    I'm selling my all fox mustang stuff. Some if the things I'd be willing to ship, other stuff pick up only. I can text pictures of things if you want. Prices are pretty low, but I will consider best offers. I'm located in Rome NY.
    CSI electric water pump $100.
    460 stud girdle with polylocks $25.
    351w ProComp Single plane EFI intake with elbow, $150.
    Windsor Sr. heads, ported, bare, fits 2.02" int. and 1.60" exh valves, $300.
    Custom turbo cam, 221 int, 230 exh at .050" lift, .554" int .526" exh lift, Lobe seperation 116, $75
    302 or 351 timing covers, I have two, $20 each.
    302 oil pump pickups, $5 each.
    302 351w chrome valve covers, $20
    Bare 5.0 roller block, standard bore, $30
    302 shortblock .040" over, dissasembled, $50.
    75mm P-Mass mass air meter, calibrated for 42# injectors, with flow sheet,
    silicon connector and clamps, $75.
    75mm Pro Products EGR throttle body spacer, $25.
    5.0 EFI fuel rail with Adjustable Fuel Pressure regulator, and gauge adapter, $50.
    1990 5.0 mustang EFI wiring $20.
    11" C-4 torque converter, 3000 stall, 10.5" bolt pattern, $50.
    9 1/2" C-4 torque converter, 3200 stall, billet cover, anti balloon plate, $200.
    J.W. Ultrabell blow proof SFI C-4 bellhousing, $100.
    T-5 bellhousings $25.
    Double hump transmission crossmembers, $10 each.
    Boxed stock Upper Control arms, $10.
    3.73 8.8 rear end gears, $50.
    2.73 8.8 rear end gears, $30.
    31 spline Track lock 8.8 rear differential, with gear setup and rebuild stuff, $75.
    1995-04 front control arms, with poly bushings, and Steeda ball joints, $75.
    1979-82 taillights, one damaged, $10.
    1983-86 taillights, $25.
    1987-93 taillights, $25.
    1979 door panels, $20.
    1987-1993 fuel level sender, NEW, $25.
    1987-93 gauge cluster, 140mph, $25.
    T-top glass tops, two passenger side, one driver side, $50 each.
    1979 fuel filler neck, might fit other years too, $20.
    4 fox mustang Throttle cables, assorted lengths, $20.
    Seat brackets, $20.
    5.0 rear springs, $20.
    5.0 front springs, $20.
    5.0 street/strip front springs, one coil cut, $25.
    Cowl gauge holder, $10.
    8.8 Moser 31 spline Lincoln Mark 7/ SVO length forged axles, 5 lug, with studs, NEW in box, $150.
    8.8 Superior 31 spline, 5 lug, stock Fox length, with New bearing and seals, NEW axles, $200.
    5.0 engine accessory brackets,
    2.3 Garrett turbos, 60A/R comp, .63 A/R exh., $50 for the pair.
    For sale list updated. Thanks.
    Jess
    Previously owned;
  2. #27
    Quote Originally Posted by slopoke76 View Post
    price on heads shipped? 39421
    $81 each. 57 pounds each boxed up.
    Jess
    Previously owned;
  3. #28
    Quote Originally Posted by Sir Guts View Post
    Hate to be this guy but life kicked me in the butt and I am strapped for cash now so I wont be able to take it off your hands right now but if you still want to price check it for 85023 and if you still have it in a couple of weeks ill still take it but for the time being ill have to say give it to someone else if they want it...
    Via UPS. 31 pound box, 11"x11"x10"= $69.68 for Ground. Crazy expensive. If I still have it when you are ready I can see if I can get it into a USPS flat rate box. That would be cheaper.
    Jess
    Previously owned;
  4. #29
    Is this a 157 or 164 tooth belhousing?
    Any idea of the SFI date on it?
    Price shipped to Gaffney, SC 29341.
    Ron
  5. #30
    Jess
    yikes I had a feeling it would be pricey but damn! I checked the flat rate box and it seems like it'll more around 20 bucks so if that's the case that is much more doable ill be back in a week! lol thank you for checking
  6. #31
    Quote Originally Posted by Frankensteinlx View Post
    Ron
    157 tooth. SFI date is many years expired, I can check to get you a exact date if you like. I'll round up a box and get you a shipping quote. Might take a couple days.
    Jess
    Previously owned;
  7. #32
    Just shipping price is fine.
    Thanks...
  8. #33
    Ron
    UPS ground is $34.
    Jess
    Previously owned;
  9. #34
    Dec 2006
    Greensboro, NC
    I'm interested in one each of the above (if the wiring harness is still available). How are the surfaces on the covers where the water passes through? Smooth or pitted? Also, what would be the shipping cost to North Carolina? Thanks.
    Stock bottom end, Comp Cams XE264HR-14, GT-40P heads w/ Alex's springs, Weiand 8124 Street Warrior
    8.8 Turbo Coupe rear end w/ 3.55 gears, Lincoln 73mm front calipers, SVO M/C
    My photo website:
    http://www.twilightphoto.com/
  10. #35
    Quote Originally Posted by 854vragtop View Post
    Wiring is gone. Timing cover(s) is in good shape, I can send picture if you PM me your cell number. I'll need a Zip for the shipping quote. Thanks.
    Jess
    Previously owned;
  11. #36
    P.M. Sent.
  12. #37
    I got the package today. Everything just as described/photographed. Thanks Jess!
    '79 Fairmont Futura
    '79 Mercury Zephyr wagon
    '83 LTD Wagon - future Mustang "Sport" Wagon
    '84 Mercury Capri RS - 5.0 5spd
    Owner of Victory Engines and Machining, LLC
    g2G
  13. #38
    Quote Originally Posted by Flyin'Montdude View Post
    Thanks.
    Jess
    Previously owned;
  14. #39
    I found a SROD bellhouseing in my basement. $30 plus shipping
    I believe that they can be used with the Tremic TKO-500 transmissions to bolt to a SBF.
    Jess
    Previously owned;
  15. #40
    Sep 2005
    Mtn Home Air Force Base, Idaho
    Jess
    that is correct Jess. tko500/600
    66 7 Liter Galaxie 4 sale
    66 T-bird 4 sale
    67 GT500 clone
    68 Cougar 302 c4
    72 Pinto 2.3 turbo soon
    79 2.3 Turbo Pace Car
    83 5.0 5spd GLX vert
    83 GT 5 spd blk/blk
    84 GT Turbo vert
    84 v6 to 5.0 SROD hatch
    84 5.0 5 spd LX cpe
    86 Capri bubble butt, painted!
    86 5.0 5spd LX hatch
    89 5.0 aod LX hatch GRM $2007 entry 12.57 @ 111
    89 2.3 auto cpe w/v8 susp/brks/strng 4 sale
    90 5.0 aod the "cruck" a little bent
    86/90 GT 5spd, 90 met a phone poll
    92 5.0 5 spd LX coupe
    97 Taurus SHO, i weld cams
    www.j4jps.com
  16. #41
    Sale pending on the Turbo cam, 140mph gauge cluster, Throttle cables, P-mass mass air meter, EFI intake, passenger side 83-86 taillight, 31 spline track lock and 31 spline Strange axles.
    I will update the list in a few days, it's getting smaller. If you see something you like, jump on it before it's gone.
    Jess
    Previously owned;
  17. #42
    How much to ship the SROD bellhouseing to 55447?
    - CA car, 5.0 w/5 speed
  18. #43
    Quote Originally Posted by banzaibullitt View Post
    Shipping will be $26.
    Jess
    Previously owned;
  19. #44
    FEP Supporter GT Town's Avatar
    Apr 2018
    Batesville, IN
    I’m interested in a timing cover and stock tail lights for 1985 GT.
  20. #45
    FEP Power Member Fearnot's Avatar
    Concord NC
    Could you text me some pictures of the 79-82 taillights?
    704-562-4433
    88 Turbo Coupe auto
    88 Turbo Coupe 5spd
    79 Fairmont Futura 4.6
    80 Capri 5.0/5spd project
    79 Pace Car 5.0/5spd project
    86 GT conv 5.0/5spd
  21. #46
    Replied to both. Thanks.
    Jess
    Previously owned;
  22. #47
    I'm selling my all fox mustang stuff. I can text pictures of things if you want. Prices are pretty low, but I will consider best offers. I'm located in Rome NY.
    460 Swap into fox mustang headers, 2" primaries.
    Motor plate. $300.
    351w turbo kit hot side pipes, $50.*
    351w ProComp Single plane EFI intake with elbow, $150.*
    Custom turbo cam, 221 int, 230 exh at .050" lift, .554" int .526" exh lift, Lobe seperation 116, $75 *
    302 or 351 timing cover $20
    silicon connector and clamps, $75. *
    5.0 T-5 transmission with bellhousing, $300.
    Double hump transmission crossmember, modified to fit 1979 mustang $10.
    1987-93 gauge cluster, 140mph, $25. *
    4 fox mustang Throttle cables, assorted lengths, $20. *
    Seat brackets, $20.
    5.0 engine accessory brackets, Alternator and tensioner bracket. $20.
    Jess
    Updated list. Items with an * after them are sold pending payment. Thanks.
    Jess
    Previously owned;
  23. #48
    Stuff with the asterisk after it is sold.
    Jess
    Previously owned;
  24. #49
    pm'ed you
  25. #50
    Do you still have the 31 sp Trac loc unit...also does it have the big pin
    Stephen Johnson
    SS/D 427 Ford Fairlane NHRA-IHRA
    National Record Holder 9.49 @ 139mph
    1985 Mustang daily driver
    10.88mph 125mph N/A 337
