Page 1 of 4 123 ... LastLast
Results 1 to 25 of 92
    Default 20 year collection of Fox Mustang stuff
    I'm selling my all fox mustang stuff. Some if the things I'd be willing to ship, other stuff pick up only. I can text pictures of things if you want. Prices are pretty low, but I will consider best offers. I'm located in Rome NY.
    460 Swap into fox mustang headers, 2" primaries.
    Motor plate. $300.
    CSI electric water pump $100.
    460 stud girdle with polylocks $25.
    351w turbo kit hot side pipes, $50.
    351w shorty swap headers, $50.
    351w Ford motorsports intake, just like Victor Jr., $50.
    351w ProComp Single plane EFI intake with elbow, $150.
    351w rear sump swap Ford Motorsports oil pan and oil pickup, NEW, $75.
    351w Scat cast steel stock stroke crank $25.
    Windsor Sr. heads, ported, bare, fits 2.02" int. and 1.60" exh valves, $300.
    Comp Cams XE282HR cam, Hydraulic roller, 232 int, 240 exh @.050 lift, $75.
    Custom turbo cam, 221 int, 230 exh at .050" lift, .554" int .526" exh lift, Lobe seperation 116, $75
    302 or 351 timing covers, I have three, $20 each.
    302 oil pump pickups, $5 each.
    302 351w chrome valve covers, $20
    Bare 5.0 roller block, standard bore, $30
    302 shortblock .040" over, dissasembled, $50.
    1.6 aluminum roller rockers, $50.
    76mm C&L mass air meter with tubes for 42#, 24#, and 19# injectors, $50.
    75mm P-Mass mass air meter, calibrated for 42# injectors, with flow sheet,
    silicon connector and clamps, $75.
    75mm Pro Products EGR throttle body spacer, $25.
    5.0 EFI fuel rail with Adjustable Fuel Pressure regulator, and gauge adapter, $50.
    1990 5.0 mustang EFI wiring $20.
    11" C-4 torque converter, 3000 stall, 10.5" bolt pattern, $50.
    9 1/2" C-4 torque converter, 3200 stall, billet cover, anti balloon plate, $200.
    J.W. Ultrabell blow proof SFI C-4 bellhousing, $100.
    5.0 T-5 transmission with bellhousing, $300.
    T-5 bellhousings $25.
    Flaming River manual steering rack, with adapter for use with power steering shaft, $150.
    Double hump transmission crossmembers, $10 each.
    Boxed stock Upper Control arms, $10.
    1987-93 Coupe quarter windows, $20.
    Maximum Motorsports Strut tower brace, $50.
    1979-86 Aluminum Front Bumper Bar, very rare, much lighter than steel, $100.
    1979-86 Steel front bumper bar. $20.
    Assorted fox mustang driveshafts, $20 each.
    NEW Radiator Support, from Ford, $100
    3.73 8.8 rear end gears, $50.
    2.73 8.8 rear end gears, $30.
    31 spline Track lock 8.8 rear differential, with gear setup and rebuild stuff, $75.
    1995-04 front control arms, with poly bushings, and Steeda ball joints, $75.
    5.0 front sway bar with mounting brackets, $25.
    1979-86 center console with lid, $20.
    1979-82 taillights, one damaged, $10.
    1983-86 taillights, $25.
    1987-93 taillights, $25.
    1979 door panels, $20.
    6, 5.0 turbine factory aluminum wheels 15 x 7", four with tires, four center caps, $75.
    Hatch privacy shade, grey, $20.
    1987-1993 fuel level sender, NEW, $25.
    1987-93 gauge cluster, 140mph, $25.
    T-top glass tops, two passenger side, one driver side, $50 each.
    1979 fuel filler neck, might fit other years too, $20.
    4 fox mustang Throttle cables, assorted lengths, $20.
    Seat brackets, $20.
    5.0 rear springs, $20.
    5.0 front springs, $20.
    5.0 street/strip front springs, one coil cut, $25.
    Door moldings, 85-86, and 87-93, $20 a set.
    Interior trim, make offer.
    Exterior trim, make offer.
    Plastic inner fender liners $10.
    Cowl gauge holder, $10.
    8.8 Moser 31 spline Lincoln Mark 7/ SVO length forged axles, 5 lug, with studs, NEW in box, $150.
    8.8 Stock Lincoln Mark 7/ SVO axles, 5 lug, 28 spline, $25.
    8.8 Superior 31 spline, 5 lug, stock Fox length, with New bearing and seals, NEW axles, $200.
    5.0 engine accessory brackets,
    2.3 Garrett turbos, 60A/R comp, .63 A/R exh., $50 for the pair.
    Jess
    Previously owned;
    Dec 2011
    stanton,alabama
    send pics of the aluminum bumper 334-412-7399
    FEP Supporter STANGMAN116's Avatar
    Mar 2013
    DENVER CO, the 303
    Interested in 87-93 coupe quarter windows shipped to 80022
    I'm local, I'd love to take at least these off your hands:
    I'll PM you in the AM.
    -Randy
    '83 Mustang GL notchback - 3.8 C5
    '92 Mustang LX hatchback - 2.3 T5 (2.3t soon)
    Intersted in the following:
    and if NY5speed doesn't take them:
    I will send you a PM.
    Thanks, Jess
    Last edited by Flyin'Montdude; 04-08-2018 at 09:59 PM. Reason: forgot strut tower brace
    '79 Fairmont Futura
    '79 Mercury Zephyr wagon
    '83 LTD Wagon - future Mustang "Sport" Wagon
    '84 Mercury Capri RS - 5.0 5spd
    Owner of Victory Engines and Machining, LLC
    g2G
    FEP User Boxtop78's Avatar
    Jun 2017
    Stockton,California
    I'm interested in your 1.6 roller rocker. Pedestal mount.? Pic. Please
    Sent ya a PM on the Garrett turbos.
    Interested in aluminum front bumper if still available.
    1985 Capri
    347 (Baker Engineering built, Dart block, GT40x, RPM air-gap, Mahle pistons, custom cam...)
    5 speed RS
    Ext - Red/Grey
    Int - Tan
    Manual steering rack, 351 shorty headers, 351 Ford Motorsport intake, 351 oil pan, and a timing cover sold pending payment.
    Thanks for all the reply's, I've been trying to keep up. Sorry if I take a little while getting back to you.
    Jess
    Previously owned;
    Front bumper is available but I don't know how I would ship it affordably. It's too large to even put on a pallet. Lots of people interested in this one. They are way lighter than steel.
    Jess
    Previously owned;
    Comp XE282HR, C&L mass air meter, 1.6 roller rocker arms, Strut tower brace, and EFI wiring sold pending payment. Thank you.
    Jess
    Previously owned;
    Wish I was closer to you - would drive over for the bumper. Had a rear bumper shipped in a long box and it was not unreasonable. Problem most likely was finding the right box. I would mail you an empty box to have the bumper shipped back here :-)
    1985 Capri
    5 speed RS
    Ext - Red/Grey
    Int - Tan
    price on heads shipped? 39421
    FEP Supporter Saturn V's Avatar
    Jan 2011
    Houston, TX
    I've shipped a bumper cover in two tall "wardrobe" moving boxes from Home Depot ... put one on each end of the bumper and overlap in the middle, cut boxes along the length and overlap/tape to match diameter of the bumper. Look for boxes on the shelf that are beat up and ask the manager for a discount.
    Present: '84.5 Mustang GT T-top, '06 Mazdaspeed6
    Past: '79 5.0 Capri, '86 Buick GN, '90 Mustang GT, '92 SHO, '95 SHO
    Browse cover pages of my Fox Chassis related library
    31 spline Track lock 8.8 rear differential, with gear setup and rebuild stuff, $75. still up for grabs? if so dibs!!!! what would the price be shipped to phoenix, az? also what is the gear set up?
    PM sent on 1979-86 center console with lid, $20.
    GLADLY burning the fuel your Prius is saving!!
    Quote Originally Posted by Sir Guts View Post
    It is still available. The set up stuff is extra frictions and steels for the limited slip, in case you want to restack them for a tighter limited slip. Some printed directions, and I'd have to check what else. What is the Zip code you want it sent to?
    Jess
    Previously owned;
    Quote Originally Posted by slopoke76 View Post
    I'll look into it, but it'll probably be really expensive.
    Jess
    Previously owned;
    Motor plate. $300.
    Seat brackets, $20.
    Jess
    In this updated list I have removed the stuff I'm not interested in shipping. Sorry if you were interested in some of those items.
    Jess
    Previously owned;
    I’ll take the hatch shade. Shipped to 98660. Let me know how much I owe you.
    I'm #2 in line for the hatch shade if no one else takes...and it retracts. 08743-New Jersey
    1984.5 GT 5.0 5 Speed ANALOG
    BBK Long Tubes/H pipe/FM
    Edelbrock Intake/Holley 600
    8.8 w/FMS 3.73s
    Steeda Shifter
    2010 GT 5 Speed DIGITAL
    Track Pack
    Pypes Violator axle back
    Airaid Cold Air
    FEP Super Member tORMENtOR's Avatar
    Oct 2007
    Bethlehem,PA
    Is the strut tower brace for EFI or Carb?
    Current Stangs+
    84Gt (9W) T-top 347EFI
    http://www.foureyedpride.com/content...984-Mustang-GT
    84Gt(1E)Hardtop Turbo
    http://www.foureyedpride.com/content...e-of-the-Month
    84Gt(1C)Sunroof 306
    86 SVO 1E Sunroof
    Strut tower brace is sold. Hatch shade is spoken for.
    Comp XE282HR cam is sold, as is the C&L mass air meter, 1.6 rocker arms, and EFI wiring.
    Thanks.
    Jess
    Previously owned;
    Dec 2009
    St. louis MO
    Jess, send some pics of the tails when you get a chance.
    Keith formerly STLPONDS
    '79 V8 coupe in the works!
    Jess
    Hate to be this guy but life kicked me in the butt and I am strapped for cash now so I wont be able to take it off your hands right now but if you still want to price check it for 85023 and if you still have it in a couple of weeks ill still take it but for the time being ill have to say give it to someone else if they want it...
