Page 2 of 2 FirstFirst 12
Results 26 to 42 of 42
  1. #26
    They should come with silicone grease. It just takes a film on every part as you go together... at least that's what I did. It also aids assembly. Then I put a few drops of 90w on the bolts before I put them in ( future insurance, hopefully)
  2. #27
    Thanks!
    - CA car, 5.0 w/5 speed
  3. #28
    FEP Member 4eyed85gt1's Avatar
    Oct 2010
    Lakeside, California
    With all that said..and thanks again for all the info....I'm gathering up parts for suspension upgrade...New poly bushings in front control arms..c/c plates coilovers full length sub frame connectors, rear upper lower control arms from maximum motorsports rear shock tower brace ..my question is where is there a shop with knowledge of these cars and the ability to install a but load of parts and do the proper wheel alignment and other refinements..I'm located in lakeside California..just outside San Diego
    85 ford mustang gt 5.0 h.o.5 spd
    68 chevy nova SS 350 (slightly modded)
    92 ford ranger prerunner
  4. #29
    Oct 2010
    I'm gonna bit the bullit and go with maximum motorsports front control arms ...I like there stuff good quality part....most of my upgraded suspension will be maximum motorsports
  5. #30
    Quote Originally Posted by 4eyed85gt1 View Post
    There is . . . but we are not located in CA.
    Good luck with your suspension upgrades! I am sure you will love it!
    1984 SVO Awaiting Restoration
  6. #31
    It's been a while, so here's a quick update... The bushings will not go in all the way by hand or hammer, so I used a ball joint removal/ install tool to press them in all the way. No issues, and no modifying the poly bushings.
  7. #32
    Sep 2011
    Central,Wisconsin
    Quote Originally Posted by banzaibullitt View Post
    The final test will be after putting the final torque on the mounting bolts.
    **If after torquing down,the a-arm doesn't slowly swing down under it's own weight you know the bushings are binding and the faces of the bushing will need to be trimmed.**
    Not only is this the proper way, but it will prevent the dreaded poly squeak from the faces of the bushings being over compressed against the mounts.After being pressed into the a-arm the faces of the poly bushings should be even with and not extend past the face of the inner sleeve.
    Good luck
    '86 Med.Canyon Red Met.(original paint) T-top,5 speed,3.55 rear,MAF conversion(A9L).MM adj. RLCAs,T/A,Panhard Bar,and adj MMRSB-3,rear T/A springs 375#-440#,MM C/C plates,MM 1.125" dia.swaybar,STB,4pt KMB,FLSFC's,'03 Cobra rack-n-pinion w/ Saginaw pump conversion.Bilstein MM coilover conversion and A-arms,front spring rate:250#.
  8. #33
    Quote Originally Posted by OldManRiver View Post
    Good luck
    Too late. The front suspension is back together. When I was taking everything apart, the a-arms didn't move by themselves with the old bushings still in. I guess I'll just drive it and see what happens.
  9. #34
    Im in the same situation as you with the untrimmed bushings already being installed. Im going to assume its a non issue, but keep us posted about how it works out for you!
    Tony
  10. #35
    For what itís worth, ready to go control arms are SO inexpensive compared to the labor. They donít have this trimming problem either.
    Low friction balljoints install more easily too. food for thought.
    sometimes itís about choosing what to do.
  11. #36
    Quote Originally Posted by flinfantryrebel View Post
    I'll let you know. It will probably be another week, because I'm in the middle of doing a 4 wheel disc swap.
  12. #37
    Finally got the brakes done and drove the car.
    flinfantryrebel, No squeaks or other issues.
  13. #38
    I recently looked them up. They're more like $100 each, these days.
    Not from LMR. $44.99
  14. #39
    Good luck
    I did not have to trim the poly bushings.
  15. #40
    Sep 2011
    Central,Wisconsin
    In my post I never stated it was something you "have" to do,I just like to do things right the first time.
    Reducing bind by installing poly bushes is the goal majority of folks are after.
    The squeak may still come when the grease on the faces no longer does it's job.
    Good luck
  16. #41
    Good deal - glad you got it back up and going!
    Redoing a front end is a lot of work!! if I do one again I have some lessons learned that make it easier. The main one is once the bushings are at length you can compress the spring right through the control arm and put the A arm bolts in.
  17. #42
    FEP Supporter Broncojunkie's Avatar
    Barboursville, WV
    We were discussing control arms. They're $130 each at LMR.
