Results 1 to 4 of 4
    Default 86 coupe project
    I just bought an 86 notch that needs everything.
    I am glad this site is here
    my plan is to do the 5 lug brake swap first probably cobra but sn 95 is a possibility unless the cobra brakes are that much better
    then maximum Motorsports torque arm and coil over fronts only
    The engine is up in the air but probably supercharged. I used to have an 86 convertible that I had a B and M on it was a powerdyne before powerdyne bought them
    interior or is mostly gone can a later model center console be modified to fit?
    What year front caliper brackets will work for the swap 94-04?
    any links to the most comprehensive parts list for the swap?
    thanks from a new guy
    Todd
    Apr 2016
    Sprague River, OR
    Yes, but you either need to modify the dash to fit with it, or swap to a later dash.
    There aren't separate brackets, just the spindles. If you're using the Ford K-member, use the 94/95 spindles. If you're usinf an MM K-member, look at the 96-04 spindles.
    Look at the sticky in the "wheels / Tires" section.
    Welcome to the site. We were all that new guy at one time. I refuse to give up that status.
    Join The Conversation
    Thanks for info. Just found a pair of 94 spindles and brackets for 90 dollars. So the build has officially begun
    Welcome!
    Hit the 5 lug conversion thread.
    You said supercharger.... there is good info here on how to make a 315/35/17 fit out back without adding tubs! That should have a shot at holding the power.
