Results 1 to 10 of 10
    Default C3 auto trans modulator. Which one?
    I want to replace the vacuum modulator on my transmission (1986 Capri 2.3L, C3 auto), but it appears that there are several different calibrations- denoted by colored stripes on the modulators. The problem- my modulator is completely rusty, so if there was a stripe on it, it's gone! So what do I do? Looking in my Ford dealership manuals and spec books, they still list a few different types. Is there an adjustable modulator available for the C3 so I can tune it?
    86 Mercury Capri GS 2.3L
    11 Ford Ranger XL 2.3L
    10 Ford Focus SE 2.0L
    19 Years of Foureyedpride.com
    St. Louis, MO.
    I am curious as I have a C3 in my 85 2.3. Found this list, looks like it should have a black stripe.
    http://www.rostratransmission.com/tr...on-listing.php
    Scotty
    Past Pony's.....
    That's a good question. My Ford shop manual lists "Yellow/Olive", "Yellow/Yellow", and "Olive/Silver" for the Single Area Diaphragm modulators and "Black/Olive", "Black/Yellow", and "Black/Silver" as the High Altitude Diaphragm modulators.
    St. Louis, MO.
    Hmmmmm, Rockauto lists about 10 of them and Autozone list only 1.......?
    Scotty
    Past Pony's.....
    Yea. Napa also lists one too. But I don't trust that at all. Rockauto seems to use the shotgun approach- "It could be any of these!"
    I'd like to find an adjustable one and play with it to see if I could get nice firm shifts out of it consistently.
    St. Louis, MO.
    Curious to see what you can find and I hope mine last long enough for an engine swap.
    Scotty
    Past Pony's.....
    Went out to the garage today to take a second look at the modulator. After doing some cleaning with some Brakleen, I can see some faint numbers on it. When it gets warmer, I'll put it up on stands and crawl under to see if I can read the numbers.
    Well, I got ambitious and put the car up on jackstands.With the assistance of my wife, we were able to make out the numbers on it. 83DT-7A377-C1B. In my repair manuals, there is an 83DT-7A377-C2B, so I would assume that's it. The only other one that would be close would be a ...-D2B, but it's definitely a C and not a D on my modulator. That makes it either an olive or yellow/olive type modulator.
    St. Louis, MO.
    You have me curious about mine now if it's the same as yours.....I might have to go under the 85 and check it out.
    Scotty
    Past Pony's.....
    I would be curious to know as well.
