    Default 1984 GT Turbo convertible
    Has anyone had or heard of a GT Turbo Mustang with a W engine code instead of T
    ALL 'Turbo GT' had a "W" engine code in the VIN. In 1984 the "T" engine code in the VIN was for the SVO only.
    Capri and Mustang turbocharged 2.3L engine VIN codes:
    1979 = W
    1980 = A*
    1981 = T
    1982 = T
    1983 = W
    1984 = T (SVO) or W (Turbo GT/Turbo RS)
    1985 = T
    1986 = T
    *Non-turbo 2.3L and turbo 2.3L engine had same engine code (A) in the VIN in 1980.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    That makes sense - I think I got some bad data
    1984FORD MUSTANG VIN DECODER
    Engine Code /Engine/Body/Options
    * 1FA ... Ford Motor Co.
    * B ... Restraint system (B-active belts)
    * P ... Passenger Car
    * 26 ... Body code (26 - 2dr sedan, 27 - 2drconvertible, 28 - 3dr hatchback)
    * A ... 2.3L 2V 4cyl 88hp
    * T ... 2.3L EFI 4cyl 145hp (Turbo GT)
    * W ... 2.3L EFI 4cyl 175hp (SVO)
    * 3 ... 3.8L EFI V-6 120hp
    * F ... 5.0L EFI V-8 165hp
    * M ... 5.0L EFI V-8 175hp (HO)
    * 6 ... Check digit (varies)
    * D ... Year (D - 1983)
    * F ... Plant (F-Dearborn)
    * 000001 ... Consecutive unit number
    Yes, that's bad info for sure. And those T and W engine code mix-ups are not the only two errors.
    This is what it should be...
    * W ... 2.3L EFI 4cyl 145hp (Turbo GT)
    * T ... 2.3L EFI 4cyl 175hp (SVO)
    * M ... 5.0L EFI V-8 165hp (HO)
    * M ... 5.0L carb V-8 175hp (HO)
    * E ... Year (E - 1984)
    And that is why you need not trust any other VIN decoder than the one on this site.
    http://www.foureyedpride.com/content...de-VIN-Decoder
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    FEP Power Member 86-TC/SVO's Avatar
    Aug 2010
    Connellsville, Pa
    The 1988 Thunderbird Turbo Coupe has the T for the engine code also. Why it was changed from the older models (83-87) is beyond me just for one year.
    86' SVO 1C # 17 of 3379 86's #6475 of 9837
    86' SVO 1C #497 of 3379 86's #6955 of 9837
    84' GT Turbo #4 of 3241 GT Turbo HB's #560 of 3935
    87' Thunderbird TC 1 of 10
    http://www.foureyedpride.com/content...e-of-the-Month
