I have a 1982 Mustang GLX with a 3.3L straight 6. Its my first car but ive done alot of research on it but just found the build sheet. Is there anywhere that i can decode the build sheet?
Thanks in advance!
Thanks in advance!
Please post the door tag and buck tag. I can decode them all this weekend.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
Does this GLX have interval windshield wipers? (Twist knob on end of wiper switch for wiper time delay, in addition to normal off/low/high.)
How many miles are on the odometer?
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
No, just off/low/high, and there are currently 47,175 miles on the odometer. In 2002 it was reported having 42k but im not sure if those are original or not.
VIN
B = active belts, no airbags
P = passenger car
13 = Mustang GLX 3-dr hatchback
B = 3.3L I6 engine
X = VIN check digit
C = 1982 model year
F = Dearborn Assembly
183003 = 83,003rd 1982 Ford scheduled for production at Dearborn Assembly
Door Tag
Date - 04/82 = April 1982 scheduled build
GVWR - 3940 lb/1787 kg = gross vehicle weight rating
Front GAWR - 2098 lb/951 kg = front gross axle weight rating
Rear GAWR - 1863 lb/845 kg = rear gross axle weight rating
F0152 = 152 lbs front accessory reserve load
R0131 = 131 lbs rear accessory reserve load
Exterior Paint Colors - 1P = Medium Grey Metallic
DSO - 13 = New York district sales office
Body 61H = Mustang GLX 3-dr hatchback
Int Trim - CD = vinyl seating, low-back front buckets (C), Medium Red interior trim color (D)
A/C - A = manual air conditioner
R - 7 = AM/FM stereo cassette radio
S - C = sunroof
Ax - 8 = 2.73:1 axle ratio, conventional (non-locking) differential
Tr - C = C5 automatic transmission
EE = front springs
HH = rear springs
Buck Tag
MUSTANG = Mustang model line
B = 3.3L I6 engine
MO = moonroof (sunroof)
072_ = body & paint rotations #072_
1PP = Medium Grey Metallic exterior paint color
DF
ST
RW = rear washer/wiper
AC = manual air conditioner
03 = YES rear defrost, YES rear washer/wiper, NO rear louvers, NO rear wing
RM = rocker molding
01 = no hood scoop
V = visibility (light group)
ELECTRIC
-D = Medium Red interior trim color
Build Sheet
Line A
Rotations Number - 0567 = trim & chassis rotations #0567
Line - Z = Mustang model line
VIN - P13CF183003 = [VIN decoded above]
Body Type - 61H = Mustang GLX 3-dr hatchback
Body, Tops, Roof - 7 = Sunroof
Ext, Paint, Body - 1P = Medium Gray Metallic
Ext, Paint, Accent - [blank] = no accent paint
Ext, Tutone - [blank] = no tu-tone paint
Int, Trim - CD = vinyl seating, low-back front buckets (C), Medium Red interior trim color (D)
Int, Dev - [blank] = no interior trim deviation
Inst BD - D = Medium Red instrument panel color
Type of Order - ?
Region & District - 13 = New York district sales office
Line B
Emission Control - [blank] = no special emissions package
Engine - B = 3.3L I6 engine
Trans - C = C5 automatic transmission
Air Cond - M = manual air conditioner
Engine, Tag Number - CJ222AA = 49-state calibration (C), Thermactor emissions with A/C (J), 3.3L engine (206), release level AA
Transmission, Part Number - E2DP CA = automatic transmission (P) originally engineered for 1982 (E2) Granada (D), release level CA
Seats, Type - 2 = low-back bucket seating
Belts, Color - D = Medium Red seat belts
Line C
Imm Block Heater - [blank] = no immersion engine block heater
Line D
Groups, Protection - [blank] = no appearance protection group
Electrical, Wipers - R = NO interval windshield wipers, YES rear washer/wiper
Electrical, Defroster - E = electric rear defrost
Electrical, Audio, Radio - R = AM/FM stereo cassette radio
Electrical, Audio, Spkrs - 4 = four speakers without premium sound system
Electrical, Lights, Light Group - V = visibility/light group
Power Aids, Deklid Release - [blank] = no remote decklid release
Power Aids, Windows - [blank] = no power side windows
Glass, Window Opt - [blank] = no rear louvers
Mouldings, Rocker - R = rocker panel mouldings
Mouldings, Bodyside, Color - P = Light Grey/Pewter
Carpet/Mats - [blank] = no floor mats
Stowage Area - [blank] = no cargo area cover
Console - [blank] = no console
Mirror, Vanity - P = passenger side vanity mirror
Mirror, Outside - B = dual remote control mirrors
Line E
Battery - DA = regular duty battery (45 amp-hr)
Driveline, Speed-O, Metric - [blank] = no metric speedometer
Driveline, Rear Axle, Tag Number - 275D = 2.73:1 axle ratio, conventional (non-locking) differential
Suspension, Springs, Front, Left - W0E = E front left spring code
Suspension, Springs, Front, Right - W0E = E front right spring code
Suspension, Springs, Rear, Left - N0L = H rear left spring code
Suspension, Springs, Rear, Right - N0L = H rear right spring code
Pkgs, Hndlng - [blank] = no handling suspension package
Line F
Wheel Area, Wheel Covers - F = unknown wheel covers
Wheel Area, Wheels, Code 1/2 - VV = steel wheels
Tires, Size - 1757JR4 = P175/75R14 tires
Tires, Color - [blank] = black sidewall
Tires, Spare - M = unknown spare
Tires, Quantity - 4 = four full size tires
F28 - [blank] = no fingertip speed control
Front End, Steering Wheel, Wheel Color - D = Red steering wheel
Hood Scoop - [blank] = no hood scoop
Frt License Plate Bracket - X = front license plate bracket
Line G
Accent Stripe Color - E = Bright Red paint stripes
VIN - 1FABBX = [VIN decoded above]
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Thank you so much! You let me know that my car was 100% original when i bought it minus a later model wing on the back. I really aprreciate that. Much love
