Results 1 to 6 of 6
    Default Cowl hood for fairmonts
    Does anyone offer a cowl hood for fairmonts? I have a 78 futura with a motor swap and the intake interferes with the hood a decent amount.
    I’m looking for a 4+” cowl but all I see is the add on cowls that will look like total crap I assume.
    Also I’m blown away how heavy the trunk lid is on this car, anyone offer a fiberglass one?
    Sep 2016
    Anchorage Alaska
    http://usbodysource.com/
    Click on the add a scoop option.
    Dec 2009
    St. louis MO
    Keith formerly STLPONDS
    '79 V8 coupe in the works!
    Jan 2011
    Vancouver BC Canada
    Personally, I think any cowl hood looks like crap on a Ford. Ford made a number of nice looking hood scoops over the years, that would look better, AND actually serve a function than just block you vision.
    Mar 2013
    Where the Navy sends me...
    Quote Originally Posted by Dr. Matt View Post
    Interesting. Anyone have any weight #s for their parts? I may spring for all 3 parts eventually, if the weight savings are worthwhile.
    Jan 2011
    Vancouver BC Canada
    Many years ago I ordered a Fairmont fiberglass hood for my 78 2 door sedan, but ended up never installing it. The quality looked very good, but when I weighed my stock hood and the fiberglass hood, there was only 7 pounds differance. The stock steel hood just isn`t terribly heavy. For that little bit of weight, having to paint the hood, and having to make it a lift off, I decided to keep the stock hood and hinges, much more convinient. The stock trunk lid is fairly heavy, but since its at the rear of the car, I left that stock too. And since my car came with nice, straight "naked" bumpers , I kept them as well. The stock bumpers are aluminum, and after I removed the energy absorbing shock stuff, and the bolted in bracing inside the bumper channel, I weighed the OE bumpers, and was suprised at how light they were.
