Today I was trying to replace my damaged tail light harness on my '85GT T-TOP CAR. I have a sumped Aeromotive fuel tank I am trying to install also. Anyway, I only see a fuel level wiring connector with two wires going through the trunk floor on my original harness. New harness from member here has a four wire connector. Would like to be able to power up new aftermarket fuel pump (Aeromotive A1000) with the factory harness plus hook up my fuel level sending unit. Maybe the original fuel electric pump and fuel sending unit we're altogether as one unit on the tank? Not sure if '85 had electric or mechanical fuel pump from factory. On my Aeromotive fuel tank, I only have the sending unit mounted on lower level of fuel tank top surface. On the raised area of fuel tank, I have a block off plate where factory pick up tube was mount prior. I guess worst case I could run new wiring for new electric fuel pump. Pics are welcomed!
