Body shop decided to drill out rivets and remove LTD door handles.
(before paint).
Any reason these will not work on LTD?
https://lmr.com/item/LRS-22404CH-K/1...ching-Hardware
(before paint).
Can't imagine there is any difference. I don't rivet them back in though. I use stainless steel button head bolts with a nylon lock nut. No worries about the rivet gun slipping when the rivet snaps off and scratching brand new paint.
