Results 1 to 9 of 9
    Default Underhood Lighting Assembly
    Does anyone know where I can find the underhood lighting housing/assembly along with the switch om the firewall? I’m missing this on my car and would love to replace if possible. Thanks In advance
    Previous:
    79 Notchback
    86 GT
    93 GT Convertible
    Current:
    86 GT Convertible
    Default underhood lights
    dunno where to find that one.
    Best i can say is use that dim low candlepower thing to find this truck one that can be installed hidden anywhere.
    One neat cool item that needs to be saved from scrap heaps. 1.00-5.00.
    90's GM pickups, suv.
    Has switch, #97 size bulb, 18' cord on reel. See LED upgrade in link below. Or LED that factory one.
    Guess Ford trucks had similar as accessory with mercury switch, no crank, 80-89. E2TB-15550-AA.
    Also known new as Stewert Warner-Hobbs 79550 emergency magnetic trouble/underhood light.
    Am going to snag a few more for the Mustang hatchback area and my Ranger.
    http://www.fourwheeler.com/how-to/el...od-reel-light/
    Sep 2014
    Freeport NY
    Quote Originally Posted by Matt1986gt View Post
    I used this one from an 84 Escort. Its the same light just slightly different harness length and connector, but I made a mating connector and wired it direct to the + side of the starter solenoid.
    It doesn't need a switch its got a mercury switch inside.
    https://www.ebay.com/itm/NOS-1984-85...item56754b7ff2
    I pucked this up off ebay
    Previous:
    79 Notchback
    86 GT
    93 GT Convertible
    Current:
    86 GT Convertible
    Ebay
    MPS in Georgia
    Out to pasture Ppny parts
    Junkyards for any mid 80's Ford
    1986 GT T Top- stock except for magnaflow cat back
    1990 LX vert- 500hp V3 and all that stuff
    2013 GT- usual bolt ons
    FEP Senior Member fascat's Avatar
    Greensburg, PA
    I have a working underhood light for an '86 Mustang. I bought it thinking it would be the same for an '86 Capri but it is different. Here is a picture of it. I'll send you a pm.
    Sep 2014
    Freeport NY
    I suggest a LED from superbriteleds.com It will light up the whole driveway in the night and it barely takes any juice from the battery if left on a while.
    https://www.superbrightleds.com/more...retrofit/3698/
    Quote Originally Posted by fascat View Post
    JimI just sent you a pm about this after I found the original thread. This is much nicer than the one that came in the mail. Has this one been tested? The one I got looks to be a bit rusty so the connection isn’t great. Let me know if you still have this
    Previous:
    79 Notchback
    86 GT
    93 GT Convertible
    Current:
    86 GT Convertible
    FEP Member jacquejp's Avatar
    Jan 2012
    Port Washington, WI
    I grabbed one from a Tempo. It seems like they double the price if it is from a Mustang.
